Myford M type question
Home › Forums › Workshop Tools and Tooling › Myford M type question
  • #310162
    Brian Moss
      @brianmoss64697
      Can anyone tell me what is the distance between centres on the Myford M type lathe?
      #18606
      Brian Moss
        @brianmoss64697
        #310281
        David George 1
          @davidgeorge1
          Hi Brian just measured my M type and i can just get just over 17 inch but there is a long bed type I don't know about.
          David
          #310285
          Brian H
            @brianh50089
            Have a look at **LINK**/.
            Brian
            #310294
            Ady1
              @ady1
              17 inches is about right on a non-longbed version
              Between centres is exactly that, no chuck, centres only
              #310304
              Ady1
                @ady1
                The longbed is about a foot more, officially, 28inches (2 feet 4 inches)
                #310305
                Brian Moss
                  @brianmoss64697
                  Hi Ady,
                  Many thanks for that. Do you know of anyone selling one at the moment?
                  Brian.
                  #310308
                  Ady1
                    @ady1
                    Ebay is your best bet, but an internet search can sometimes yield results
                    You need to be patient nowadays when you're looking for stuff, it can take a few months for anything decent to appear
                    I have seen the bed on it's own being advertised a few times too, so you can cobble one together from two lathes but the best scenario is always a complete unit
                    Longbeds were all late production stuff and were being sold up to the early 1950s so had all the most up to date bits of the design
                    Edited By Ady1 on 04/08/2017 10:18:32
                    #310310
                    Ady1
                      @ady1
                      My only advice would be do not get an early version, even if you're desperate
                      Tthe headstock bearings in the later versions were far better, ideally don't get a pre war one, get a later one with the v-belt headstock pulleys, not the flatbelt pulleys
                      2cents
                      #310312
                      Brian Moss
                        @brianmoss64697
                        Many thanks. I'll keep an eye out on line to see what turns up in the next few months,
                        Brian.
                        #310313
                        Ady1
                          @ady1
                          Decent drummonds are like buses
                          Nothing nothing nothing….. then 3 suddenly appear in the same week
                          #310441
                            The flat belt models work quite well if you use a poly V belt running on the original flat pulleys. But definitely stick with the post-1924 models with the heavier bearings etc. There have been a couple of good ones on eBay UK in recent times so keep an eye out and you might get lucky.
                            #310639
                            Brian Moss
                              @brianmoss64697
                              Many thanks for your advice. I shall keep scanning Ebay etc. from now on!
                              Brian.
