Connecting Rod
Connecting Rod
Home Forums Locomotives Connecting Rod
  • #376095
    VC
      @vc44480
      Hi all
      Some advice please
      Want to try and use my home made CNC mill Mk I Steig
      to make a connecting rod for a 3 1/2 loco
      Would like to know what SS flat bar to buy Size 1/4 *1 *71/2
      and were to buy it
      Have looked on Flea Bay 316 Marine grade will this be OK or to hard ???
      Thank you
      VC
        @vc44480
        #376101
        John Rudd
          @johnrudd16576
          #376124
            See if you can get some 303 as it's easier to machine.
            Philip Powell
              @philippowell34749
              I think you will find 316 or 316L much easier to machine. 316 cuts nicely but can be a bit stickey when tapping. 316 will also give a lovely finish especially if you use coolant.
              Phil.
              #376133
              Ian P
                @ianp
                Posted by Philip Powell on 15/10/2018 21:53:13:
                Phil.
                Easier that what?
                In my experience 316 is much easier than Titanium
                #376134
                Ian P
                  @ianp
                  Neil is right. Use 303 SS, it machines beautifully, even easier to work than leaded steel. Its a bit harder to get the deep polished lustre as is possible on 316 but thats probably not applicable to a con rod.
                  Ian P
                  #376204
                  VC
                    @vc44480
                    Thanks very much for the reply's
                    Looks like 303 is the way to go but nobodies is saying where to get it from
                    Mac has 316 so if I can't get the 303 will give that a try
                    Cheers
                    #376212
                    Ian P
                      @ianp
                      Odd that nobody has told you where to buy 303 SS from, its not a state secret or anything.
                      Where you get it depends on your own preferences and location etc. My first port of call would be Noggin End followed by M-Machine but there are probably about 8 or 10 suppliers serving the model making fraternity.
                      Ian P
                      #376237
                          303 is not that common in flat which the OP wants unless he likes making a lot of swarf, 316 flat is easy enough to get hold of
