The other day I noticed that the front of the carriage on my CL300 lathe had a bit of vertical movement. For those who don't know, the adjustment comprises a metal plate (front and back) which clamps under the lathe bed ways. Adjustment is via 3 clamping screws plus 2 jacking screws to set the amount of clearance. In my case the jacking screws were redundant as they had to be backed right out in order to clamp the other screws sufficiently to adjust out the vertical play. It is now OK but when it needs to be adjusted again, I think I have 3 options.
1 Remove the plates and machine them flat.
2 Clean up the other side of the plates and turn them over.
3 Make some new ones.
If I went for option 3, what would people advise I made them from. Mild steel, cast iron or some form of bronze?
