large four way toolpost
Home Forums Manual machine tools large four way toolpost
  • #467011
    old mart
      @oldmart
      _igp2585.jpg_igp2578.jpg_igp2577.jpgI bought a 4 way toolpost on ebay the other day, it turned out to be bigger than expected. There was very little information about the toolpost from the seller, and I thought I could tell the size. Fortunately, it went for a very low price and I am deciding if it can be used on the Smart & Brown model A at the museum. It could fit directly to the cross slide in place of the compound slide, to add stiffness, or as a rear toolpost to use with larger boring bars. A 20mm square tool fits easily, and 25mm size would as well. I haven't been able to take it to bits yet, maybe someone will know how to. The eight clamping bolts are 3/8" 16tpi, with 3/8" square tops. The four threads in the base are a bit of a mystery, too big for 1/4" and not big enough for 5/16", the only thread left would be 7mm which is rather rare.
      Here are some pics:
      #13852
      old mart
        @oldmart
        #467013
          Biased, but my choice would be as a rear toolpost.
          #467087
          old mart
            @oldmart
            Does anybody know which lathe it is from?
            #467088
            old mart
              @oldmart
              #467269
                Posted by old mart on 25/04/2020 15:45:42:
                … The eight clamping bolts are 3/8" 16tpi, with 3/8" square tops. The four threads in the base are a bit of a mystery, too big for 1/4" and not big enough for 5/16", the only thread left would be 7mm which is rather rare.
                Could they be 9/32nd BSF? (A little over 7mm, but imperial like the others.)
                old mart
                  @oldmart
                  I have solved one part of the puzzle, the threads underneath are 5/16 UNC. I made an impression of the threads and found the pitch to be approximately 16 to 18 tpi. That definitely narrows it down to BSW or UNC. I had tried what was probably a BSW bolt without it screwing in, but today I had another search of the garage and found a bolt with the nuts on it. The nuts were too small for BSW so it is probably UNC. It is a tight fit, but screws right to the bottom of the hole. Not being able to get to the workshop at the museum because of lockdown is a handicap.
                  I still will need to strip it down before deciding what to do with it, the rear toolpost for larger boring bars is current favourite, it will be much stiffer than any standard one can be, and 25mm left hand bars will fit it.
                  I will be asking about this toolpost on the Home Shop Machinist to increase the chances of somebody recognising it.
                  #467693
                  old mart
                    @oldmart
                    If anybody is interested, I have succeeded in getting the toolpost to bits, pictures of its guts here:
                      Posted by old mart on 28/04/2020 20:22:40:
                      I would be interested, but every image link there returns:
                      Invalid File Specified
                      … So presumably one needs to be a member
                      old mart
                        @oldmart
                        _igp2590.jpg_igp2589.jpg_igp2588.jpg_igp2587.jpgSorry, I forgot that their new format won't allow viewing unless logged in, I hope it can be remedied.
                        Here are the pics:
                        #467840
                        old mart
                          @oldmart
                          It is a clever design using a hurth coupling to align and spring loaded balls to hold the post while the coupling is being tightened down. I think the post can also be locked in any of the angles allowed by the number of coupling teeth. Differential threads in the central column and at the bottom of the toolpost lock and unlock the post. The internal parts which have to be realigned are marked as such.
                          #467864
                            Posted by old mart on 29/04/2020 13:04:06:
                            Here are the pics:
                            That’s brilliant … Thank You
                            It looks a beauty
