I have some 1970's Russian microscope objective lenses that I want to use in my 1940s English-made microscope. I feel the quality of the Russian optics is a little better and the lenses are much larger diameter and let more light through.
The threads on the two tubes have the same outside diameter but unfortunately the English one is a 0.7mm pitch whereas the Russian one is a 1.0mm.
I ' think' there are two ways I could modify the Russian tube to make it fit.
(a) I could fill the thread with a hard solder and re-cut the new thread straight into the old one.
(b) Another way could be to machine back the Russian thread, glue/solder on a sleeve and recut that with the required 0.7 pitch.
I 'think' (b) sounds more sensible. Would you agree, or do you have any better suggestions ?
