Wringing gauge blocks together… in a vacuum
Home › Forums › The Tea Room › Wringing gauge blocks together… in a vacuum
  • #561649
    Grindstone Cowboy
      @grindstonecowboy
      Came across this video the other day which goes a long way towards explaining the forces involved in, and the reasons behind, the wringing effect.
      A lot of the other videos by the same presenter are equally interesting and worth a look.
      Links to https://www.youtube.com/watch?v=Z5XOk1oMFh0
      Rob
      Edited for typos and grammar blush
      Edited By Grindstone Cowboy on 06/09/2021 22:33:40
      #36551
      Grindstone Cowboy
        @grindstonecowboy
        What causes the wringing effect?
        #561664
        peak4
          @peak4
          Don Bailey made a good introductory video to their history and use; check out many other videos from the same company.
          Bill
          Edited By peak4 on 07/09/2021 02:14:54
          #561741
          Kiwi Bloke
            @kiwibloke62605
            I'm sure I've read that gauge blocks left wrung together become very hard to separate, and it's taught that it's bad to try to pull the blocks apart – they should always be slid apart. In both cases I believe that the surface can be microscopically damaged. I suspect that the microscopically thin oil film, which would be very difficult to remove, at a molecular level, and any trapped gas molecules act to make separation easier, by preventing cold welding-like effects. Surely inter-atomic or inter-molecular forces are responsible, when such welding-like behaviour occurs.
            #561932
            Bo’sun
              @bosun58570
              From my trade school days with FMC, "inter-molecular cohesion" sounds familiar. Sorry, but it was a while ago, so any explanation has long gone. Probably into the corners of the workshop with all the dropped nuts, screws & washers.
