Worn nut ACME 10 TPI Thread by 0.500 in.
Home Forums General Questions Worn nut ACME 10 TPI Thread by 0.500 in.
  • #512207
    Geoffrey Olver
      @geoffreyolver67992
      Sharp Mk ll Universal Milling Machine – Town Bent Eng. Co
      The mill knee is raised and lowered by an ACME 10 TPI thread X 0.500 in. diameter. The worn nut needs replacing. Does anyone know if the ACME thread is right handed or left handed?
      Thanks.
      Geoff
      #27813
      Geoffrey Olver
        @geoffreyolver67992
        The worn bronze nut fitted in base of Sharp Mk ll vertical mill tapped ACME 10 TPI X 0.500in.
        #512228
        Brian Wood
          @brianwood45127
          Geoffrey,
          I don't know as I don't know the machine but I am pretty sure you can establish which hand the nut is just by looking at the male ACME thread. The convention is the same as for standard screw threads and right hand nuts fit right hand threads.
          Regards Brian
          PS Welcome to the Forum by the way
          Edited By Brian Wood on 07/12/2020 18:29:43
          #512229
          Pete Rimmer
            @peterimmer30576
            Look at the screw. If it was laid flat and the threads were angled like a row of keyboard back-slashes thus \\\\, it's a right hand thread. If they look like a row of forward-slashes //////// it's a left hand thread.
            Edited By Pete Rimmer on 07/12/2020 18:33:53
            #512234
            not done it yet
              @notdoneityet
              There is little point in replacing just the nut if the screw is badly worn. That needs checking, anyway, so you might just as well check the thread rotation at the same time. It looks like it only needs a screwdriver…
              #512236
              old mart
                @oldmart
                Tracey Tools sell ACME taps in 1/2" X10 in both left hand and right hand.
                #512246
                Dave Halford
                  @davehalford22513
                  Posted by old mart on 07/12/2020 18:53:20:
                  They do , for £10 less than a bronze round nut from HPC
                  #512253
                  Howard Lewis
                    @howardlewis46836
                    Firstly, Does the handle rotate the screw, and the nut remains stationary, or is it the other way round with the nut rotating around a stationary Leadscrew?
                    If the nut rotates anti clockwise to RAISE the Knee, when viewed from above, or clockwise when viewed from beneath (i.e. screwing itself UP the shaft, the thread is RIGHT Hand
                    If the nut rotates anti clockwise when viewed from above, or clockwise when viewed from below, to LOWER the Knee, screwing itself DOWN the Leadscrew, the thread is LEFT Hand.
                    The handle would normally be expected to rotate clockwise to raise the knee, but this may not translate into clockwise movement of the threads. There could be gears between handle and the rotating parts, so you need to observe the nut and Leadscrew..
                    HTH
                    Edited By Howard Lewis on 07/12/2020 21:31:28
                    #512257
                    Pete Rimmer
                      @peterimmer30576
                      You don't have to move anyhting Howard. Just look at the male thread. The handing isn't affected by which part turns.
                      #512372
                      Howard Lewis
                        @howardlewis46836
                        Pete,
                        I was trying to help the OP answer the question as to the hand of the leadscrew and nut.
                        If you look at my profile, you will realise that I do know how to suck eggs!
                        #512387
                        Baz
                          @baz89810
                          I have just been out to the workshop and checked my Sharp Mk 2 milling machine, the thread for raising and lowering the table is RIGHT hand.
                          #512428
                          old mart
                            @oldmart
                            Posted by Dave Halford on 07/12/2020 20:54:06:
                            I would go for the HPC nut, but would check with them first just what they mean by "imperial thread"
                            #512451
                            Dave Halford
                              @davehalford22513
                              Posted by old mart on 08/12/2020 16:44:36:
                              The thread is in TPI and the diameter is 1/2" so if not imperial what? angel
                              #512466
                              old mart
                                @oldmart
                                The thread could be any one of a number of threads measured in inches. Whitworth, Unified, are a couple, but the op wants ACME.
                                #512488
                                not done it yet
                                  @notdoneityet
                                  I am wondering where the OP got the information that it is supposedly 1/2” ACME without actually checking it out.
                                  It could quite easily be a square thread (but ACME would be favourite). I doubt it is anything other than lone of those two but, like the thread direction, it needs checking before blindly ordering something that may, or may not, fit.
                                  My Raglan mill may have a square thread for the knee – it most certainly uses square threads for the other axes.
                                  #512492
                                  Mark Davison 1
                                    @markdavison1
                                    The HPC gears nut is ACME, it say "BS1104"
                                    #512579
                                    old mart
                                      @oldmart
                                      BS1104, it would have been sensible of them to advertise the thread as ACME.
                                      #512585
                                      Dave Halford
                                        @davehalford22513
                                        Posted by old mart on 09/12/2020 17:16:03:
                                        Oddly they do say Acme on the sheet for the matching leadscrews.
                                        #512596
                                        old mart
                                          @oldmart
                                          I will be doing some ACME internal threading when the museum re opens, I have to make the tooling, but have the easier task because the thread I want is 1" X 5 ACME LH and the bigger it is the easier it is.
