WM16B DRO – 2 or 3 axis?
Home › Forums › Manual machine tools › WM16B DRO – 2 or 3 axis?
  • #438431
    Bluesbreaker
      @bluesbreaker
      Hi all – first post though I have been lurking round here for a while!
      I'm fairly new to the ME hobby, and have recently acquired a Warco WM16B milling machine.
      I'm considering fitting a DRO kit from M-DRO – given that the mill already has an inbuilt digital display provided for the quill feed, are there any advantages in fitting a Z-axis sensor and 3-axis DRO, or does experience suggest that the type of z-axis display fitted to chinese mills of this level will be adequate? Is it simply a question of deciding what level of accuracy I can live with?
      #13705
      Bluesbreaker
        @bluesbreaker
        #438457
        Enough!
          @enough
          When I fitted DRO's to my WM16 lookalike I fitted one to the z-axis. It's so long ago that I don't remember the details but it seems to me that the existing readout didn't truly read the absolute position of the quill but rather linked to the quill adjustment gearing somewhere – at least part of which was a friction drive.
          Others may have a better clue on this and later machines might be different in this respect.
          It wasn't trivial fitting the DRO to the z-axis (although quite do-able).
          #438476
          David George 1
            @davidgeorge1
            Hi welcome to the forum. I have fitted an M-DRO 3 axis to my V16 mill and wouldn't be without the 3rd axis.
            David
            #438484
            Dave Smith 14
              @davesmith14
              The fitted quill DRO only reads to two decimal places, which I found limiting, so I fitted optical DRO's to the x,y and replaced the Warco Quill. If you fit a 3 axis read out and you can always decide later to do either the quill or Z
              Dave.
              #438503
              Enough!
                @enough
                Dave's post, differentiating between the quill and the z-axis made me realise I my post above is confused. To be clear, the DRO scale I fitted to mine was on the quill not the z-axis as I stated.
                #438668
                Bluesbreaker
                  @bluesbreaker
                  Thanks for all your replies and advice. I think I'll aim for a kit with a 3-axis display, and then I have the option to fit the Z-axis later on as Dave suggests.
