Why the need to “Regen” when usIng AutoCad 2000
Home Forums CAD – Technical drawing & design Why the need to “Regen” when usIng AutoCad 2000
  • #595648
    Greensands
      @greensands
      I use AutoCad 2000 which is more than adequate for my purposes for producing workshop drawings but I do find it annoying that almost after every modification there is a need to regenerate the image ((View/Regen) in order to clean up the display. Is there something which can be done to minimise the need to do this?
      #21377
      Greensands
        @greensands
        #595660
        Robin
          @robin
          Do you have REGENAUTO set to ON?
          This may or may not help, on a hard zoom my circles still become octogons until I give it a manual REGEN smiley
          #595661
          PatJ
            @patj87806
            I use AutoCad 2004, and am running into the same issues.
            For smaller files, this was not a problem, and only took a second or so for a regen, which I have on a keyboard shortcut key.
            For my current project, I have perhaps 100 drawings in one file, which is about 8MB, and the regens have become longer than I would like, along the lines of perhaps 20 seconds.
            People have said "Don't put all your drawings in one file", but the efficiency of cut-and-paste, and the quick access to all areas of the design make it the only efficient way to do the project.
            I am having to purchase a new computer, with hopes that the problem will be minimized.
            I bought an HP desktop, 32GB ram, 6GB ram on the video card.
            I hope this computer works, since I have a lot of money riding on this project.
            One thing I have found that helps is running the purge command repeatedly until the file is cleaned up.
            I have found that this can reduce a file size from 10 MB to perhaps 6 MB.
            Edited By PatJ on 24/04/2022 15:04:53
            #595766
            Paul Lousick
              @paullousick59116
              In the early versions of Autocad, when working with large drawings it is better to make the value of REGENMODE system variable to 0 to improve the performance by avoiding unnecessary automatic regenerations. But you will have to do a manual regen after zooming, etc.
              The default value is set to 1 which allows unnecessary regeneration in drawings and may deteriorating performance.
