Which silver solder
Which silver solder
Home › Forums › Beginners questions › Which silver solder
  • #65239
    Eric Cox
      @ericcox50497
      i intend to silver solder small components copper, brass,steel (EN1A) using a butane torch. Which silver solder and flux do I need.
      #5441
      Eric Cox
        @ericcox50497
        #65248
        Michael Cox 1
          @michaelcox1
          Hi Eric,
          I would use Easyflo 2 and Easyflo flux.
          #65263
          mgj
            @mgj
            Apparently Easy Flo (as a trademark) has been stopped by Johnson Matthey. So it is a case of while stocks last, if you have a particular brand loyalty to EF.
            Otherwise the same alloy remains available. CUP alloys would be a good source . I bet Thessco are still doing it too. The trade name will be slightly different, thats all.
            There are non cadmium bearing alloys wih the same properties if you want to go that route.
            If you go to CUP alloys website it will all be explained in detail.
            #65270
            KWIL
              @kwil
              There is no doubt in my mind that the non cadmium versions do not “flow” so nicely. I agree with mgj, CuP Alloys is a good source. I use their 842 range as a multi purpose alloy
              Edited By KWIL on 09/03/2011 15:35:49
