Whats this engine called
Home Forums General Questions Whats this engine called
  • #229118
    Eric Cox
      @ericcox50497
      I came across a stationary engine, similar to a steeple engine that converts the linear motion of the cylinder to the rotary motion of the crank by means of a cross (pus sign +) with two slides, one vertical and one horizontal similar to this LINK.
      Does anyone know what the engine is called.
      #24433
      Eric Cox
        @ericcox50497
        #229135
          Eric,
          Sorry, this doesn't identify your engine, but; the mechnism is known as
          the Trammel of Archimedes.
            Looks like the "rectilinear" motion found on a couple of Anthony Mounts engines. His "cross" and "Rectilinear" engines both use it
            Edited By JasonB on 09/03/2016 10:23:31
            #229144
              Eric Cox
                @ericcox50497
                Thanks, looks like Anthony Mounts engine is the one.
                #229154
                steamdave
                  @steamdave
                  Posted by Eric Cox on 09/03/2016 09:15:16:
                  You too can make one of these by following Frank Forde's instructions!
                  http://www.frets.com/HomeShopTech/StepByStep/TwoSlider/twosllider1.html
                  There are some other interesting items on his site
                  The Emerald Isle
                  #229176
                    If you go to the "Baubericht" link on the couple of engines I linked to you can see quite good build diaries
                    #229198
                    John Fielding
                      @johnfielding34086
                      I think that is the Dikes engine, designed by an eccentric American. At one time they were popular as steam winches on boats IIRC.
