What annealing temperature?
Home › Forums › General Questions › What annealing temperature?
  • #484102
    Andrew Tinsley
      @andrewtinsley63637
      I have a pair of ratchet crimping tools for crimping car battery leads amongst other things. (so they are hefty!)
      The ratchet pawl has snapped across the hole that it rotates about. As usual, no manufacturers spares are available. The pawl is almost certainly made from 1/8" gauge plate and then hardened.. The break is a clean fracture, so the gauge plate has been hardened with perhaps little or no tempering "let down".
      I can easily make another pawl or two and I have a small furnace to harden and if necessary, temper the end product Any suggestions for a tempering temperature.? Or should I just harden them without any further heat treatment? The way the pawl has snapped seems to suggest a very hard and brittle condition.
      Thanks,
      Andrew.
      #27498
      Andrew Tinsley
        @andrewtinsley63637
        #484171
        elanman
          @elanman
          Well I would temper to Mid to dark straw. Sorry I'm old school I don't know what temperature that is. Others may have different ideas.
          Cheers
          Clive Hartland
            @clivehartland94829
            As it is a pawl only the end needs hardening and tempering. heat and harde, dress off clean and then place on a hot steel block and let the colours run and as soon as dark straw reaches the tip dunk in cold water
