Weak glue recommendations needed!
Home › Forums › General Questions › Weak glue recommendations needed!
  • #818411
    John Haine
      @johnhaine32865
      I need to assemble a tiny pcb carrying some opto components into a machined brass block so it won’t come out in normal use but can be removed, for example by gentle heat or using a non corrosive solvent, later if any of the components fail. The kind of stuff that is used to lock preset potentiometer could be the kind of thing. Any recommendations please?
      #818414
      peter1972
        @peter1972
        What are you doing about insulalation between the PCB and the brass?
        Depending on how the PCB sits in the brass block, consider using small pieces of sheet foam, perhaps closed-cell foam. That’s very unconventional but you should then be able to simply pull the PCB out of the block if necessary.
        #818420
        Paul Lousick
          @paullousick59116
          Adhesive used in a hot glue gun can be softened by gentle heat
          #818422
          Grindstone Cowboy
            @grindstonecowboy
            A couple of strategically placed blobs of contact adhesive (lust left to dry, not coating both surfaces as you would usually do) would hold it firm, but would peel off either surface relatively easily.
            Rob
            #818424
            duncan webster 1
              @duncanwebster1
              Double sided sticky tape if you have a reasonable area
              #818434
                Shellac seems to fit the job-description very nicely !
                Send me your postal address if you would like a little, John.
                #818443
                Kiwi Bloke
                  @kiwibloke62605
                  All the suggestions to date seem pretty good to me. To possibly induce decision paralysis, here are some more: a blob of oil paint or nail varnish, BluTac, blob of silicone sealant (neutral cure), rubber solution (puncture repair kit), endless possibilities…
                  The light alloy reed plates in accordions are held to their wooden supporting structures by a mixture of beeswax, rosin and oil. They are intended to be removable. Proportions are not critical, approx. equal weights of wax and rosin, with a dash of vegetable oil. Easier, and probably OK, although less resilient and less sticky, would be just beeswax. It’s less brittle than ordinary candle wax.
                  #818486
                  John Haine
                    @johnhaine32865
                    Thanks all.  Shellac or nail varnish sound the best approach – I can just soak the assembly in solvent to release if needed.
                    #818490
                      Shellac liquifies at about 75° C … which would also make your board re-positionable.
                      https://en.wikipedia.org/wiki/Shellac#Properties
                      John Haine
                        @johnhaine32865
                        Positioning isn’t a problem in fact as the PCB fits in place very snugly and just needs lightly holding, but the heat removal option might be useful.
                        Thanks again everyone for the suggestions.
                        #818494
                        bernard towers
                          @bernardtowers37738
                          4 spots in the corners with a low temp glue gun
                          #818533
                          Robert Atkinson 2
                            @robertatkinson2
                            I’d second Kiwi Bloke’s suggestion of silicone sealant (neutral cure to prevent copper corrosion). Good positive hold, wide temperature range, can fill gaps but is easilly peelled or cut off when required.
                            Robert.
