vinyl wrap
vinyl wrap
Home Forums General Questions vinyl wrap
Viewing 15 posts - 1 through 15 (of 15 total)
  • #514385
    David Bothwell 1
      @davidbothwell1
      Just wondered if anyone has experience of using self adhesive vinyl wrap on model locomotives ? Over boiler cleading etc., Arguments against it? I know cars are covered in this way
      #27837
      David Bothwell 1
        @davidbothwell1
        use of vinyl wrap on model locos?
        #514389
        Ady1
          @ady1
          Helped out a taxi chap who sometimes got a "full wrap" job instead of "super sides" and the stuff they can do would cost a hand painter job 10-20k easy, plus there are no errors because its a type of cnc computer printing
          Heat is your obvious enemy but if that can be overcome the sky really is the limit
          Don't know about foil printing which would be better for heat, the whole subject has become very advanced
          linky winky
          Edited By Ady1 on 19/12/2020 17:07:09
          #514399
          David Bothwell 1
            @davidbothwell1
            Thanks ady. most useful and informative
            #514439
            Pete.
              @pete-2
              David, incase you weren't aware, car vinyl wrap and adhesive vinyl are 2 different things, adhesive vinyl has a peel off sticky back, car vinyl is applied then shrunken over the surface with a heat gun, moulding it to the contours and curves.
              #514555
              David Bothwell 1
                @davidbothwell1
                Hi Pete, Sorry for the late acknowledgement of your posting, but I was not aware, many thanks for the info much appreciated
                #514558
                Phil H1
                  @philh196021
                  Interesting link Ady1.
                  Just an observation….. have you noticed that most if not all of the cars on show (when the link is first opened) are of German origin? .They are probably considered as the expensive brands but these brands are now very common.
                  I remember when boy racers like these guys would be trying to tidy up rusty Mk1 Ford Escorts, Minis (original ones)or Vauxhall Vivas.
                  How times change.
                  #514571
                  Ady1
                    @ady1
                    Apparently it's good for a few years and he could park up against bushes and other things with no obvious effect on his advert plus the paintjob on his new 40k cab was completely protected from scratches
                    Its tough stuff and sticks hard, they use heatguns to remove it so it can deffo handle moderate heat
                    Very sticky though, even when being removed, sounds like new parcel tape, so any weakpoints like car filler or rust would probbly get yanked out when it gets pulled off
                    #514917
                      This is interesting. It could be a good solution for some of the very colourful and striking diesel and electric prototypes.
                      This would look good:
                      transportdesigned.com/train-many-colours-10-best-uk-rail-liveries-since-privatisation/
                      Edited By Neil Wyatt on 22/12/2020 12:00:35
                      #514920
                      Watford
                        @watford
                        Probably have all these liveries so that Hornby can sell more train sets !!!
                        #514945
                        Roger Best
                          @rogerbest89007
                          There will always be those who think that branding makes the world go round, bless their little technically incompetent heads.
                          #514952
                          Adam Mara
                            @adammara
                            Self adhesive vinyl comes in various guises, with different lifes and adhesives, when I was at work the vinyl was either classed a 2 year, 7 year and 10 year life. The first two were calenered vinyl and the 10 year is cast vinyl which was normally use for bady wrapping. Both my sons are factory trained appliers, but even they chickened out of doing a brand new Alfa Romeo one of our customers wanted wrapping, we got a specialist in!
                            #515604
                            Tifa 8572
                              @tifa857287838
                              I've vynil wrapped quite a few motorcycle bits & bobs.
                              A hood heatgun is essential.
                              Also, be prepared for burnt fingers. AMHIK
                              If you take your time to work it around contours properly, you can get a fantastic and durable finish.
                              Don't buy the cheaper stuff, as it's pretty thin. The thicker stuff lends itself to much more pulling and stretching around curves.
                              #515606
                              Bazyle
                                @bazyle
                                How is the artwork prepared? Is it like home made water transfers that you can design something and print it on special paper to apply to your model? bearing in mind Neil's post above and the effectiveness of the old litho printed flat steel toy trains this could be quite good for quick models for stand off scale.
                                #515610
                                Pete.
                                  @pete-2
                                  Posted by Bazyle on 26/12/2020 22:29:57:
                                  I'm not aware of any ability to print on to the car heat shrink vinyl, but if you want to create two colours joining like the photo above, you lay a line of 3m knifeless tape where you want the join, you overlap both colours, then you peel the knife less tape which slices through both layers leaving them butting up to each other.
