Air Duster
Air Duster
Home › Forums › Workshop Tools and Tooling › Air Duster
  • #851825
    jaCK Hobson
      @jackhobson50760
      I thought an air duster would work for blowing swarf off machine tools. Wolfbox get great reviews… but quite pricey. I gambled on a cheap air duster from Amazon for £20
      It worked brilliantly! But only for about 20 seconds before it sucked up a bit of swarf and jammed the fan. Luckily I managed to take it apart enough to fix. I need to fit a fine mesh filter… then I think I will have a great duster. Recommended with that one reservation.
      FYI I also have an 18V dewalt blower which I use very often – absolutely brilliant. Every now and then at the end of the day I just go around the whole workshop and blow everything with it to send the dust in the air. Then I turn the Record air filter on for 1 hour and leave. It is this that really convinced me a smaller blower would be handy.
      #851836
      bernard towers
        @bernardtowers37738
        wouldnt a vacuum do both jobs???
        #851888
        martin haysom
          @martinhaysom48469
          +1 for whet Bernard said
          #851894
          duncan webster 1
            @duncanwebster1
            Blowing dust (which is fine grit) into the air to land on machines doesn’t appeal. Vacuum far better
            #851941
            jaCK Hobson
              @jackhobson50760
              I have used a vacuum. It seems to have limitations. Maybe I don’t use it right.
