vice thread efficiency
Home › Forums › General Questions › vice thread efficiency
  • #446185
    gerry madden
      @gerrymadden53711
      Hi All,
      I'm just calculating the clamping force I can get using my large but ancient vice. Its mechanical advantage comes out at around 260 which would give some theoretically big forces but there must be some losses. Does anyone here have an experienced-based suggestions as to what this might be ? 10%, 50% 80% ?
      #27066
      gerry madden
        @gerrymadden53711
        #446191
        Vidar
          @vidar
          If it is a vice screw it can't be very efficient as that would not work for a vice. If it was more than about 50% efficient it would just backdrive instead of keeping something clamped.
          So less than 50%, and probably not even close to that as vice manufactureres likely wanted to be able to work up pressure and keep things stuck.
          #446206
          Anonymous
            The manufacturers data for my machine vice shows that the clamping force (lbs) is very roughly 90 times the torque (ft-lbs).
            #446209
            gerry madden
              @gerrymadden53711
              Thanks all. Vidar you put me on the right lines and got me thinking. I found lots of data for screwjacks and it comes down to lead angle of the thread and CoF at the thread. So in my case its going to be about 20%. And when plug this figure in I end up in Andrews ball-park ! Clever stuff, maths
              Gerry
              #446211
              not done it yet
                @notdoneityet
                Look up ‘fireball tool’ for videos on testing vises. I expect there are others, too. Then work backwards…..
                #446246
                Nick Hulme
                  @nickhulme30114
                  Your choice of friction modifier can make a difference.
