Unusual Go-No Go Tool?
Home › Forums › Workshop Tools and Tooling › Unusual Go-No Go Tool?
Viewing 25 posts - 1 through 25 (of 86 total)
  • #557695
    Martin King 2
      @martinking2
      Hi all,
      This little item was in the bottom of a crate of tooling we just got, I think it is incomplete but would love to know its specific use? Turning the end moves the pointer along the scale marked "Micrographs"
      Cheers, Martin
      #20408
      Martin King 2
        @martinking2
        #557702
          I wonder if ‘Micrographs’ might be the manufacturer, rather than the scale.
          old mart
            @oldmart
            It is obviously made to fit in a coat pocket along with pens. What happens at the buisiness end when the scale is moved?
            #557713
            Martin King 2
              @martinking2
              Nothing seems to happe when the end cap is turned, as I said it looks incomplete?
              Martin
              #557721
              DC31k
                @dc31k
                The scale on it is non-linear (perhaps logarithmic), so that eliminates a vast amount of possible applications and opens up other possibilities.
                #558043
                Chris Kirby 1
                  @chriskirby1
                  Almost looks like some sort of sighting/viewing device on top. Look through the small hole and align something within the rectangular part?
                  #558048
                  Martin Connelly
                    @martinconnelly55370
                    I wonder if the scale is logarithmic, it is clearly not a linear scale but I wonder if it is a sine/cosine/tangent curve. Is there a spring in the tool?
                    Martin C
                    #558055
                      Here’s a first stab at calibrating that scale
                      Now you can all try curve-fitting, whilst I go out for the day
                      Edited By Michael Gilligan on 13/08/2021 09:01:01
                      #558144
                      Martin Connelly
                        If you add 60 to each scale point you get close to a logarithmic progression. The deviation may be due to small errors in the numbers for the scale due to it being measured from a photo.
                        Martin C
                        #558154
                        Martin King 2
                          @martinking2
                          All waaay over my head! sad!
                          Are we saying that the tool might be complete?
                          Martin
                          #558155
                          Martin King 2
                            @martinking2
                            No spring that i can see but there does appear to be a kind of small window by the clip and as one winds the end knob a sloping point moves back and forth in the window. window is quite murky and discolored so not easy to see.
                            Hers a pretty ropy pic:
                            #558186
                              With considerably less confidence … I have inserted values for most of the sub-divisions
                              If anyone wants to play; please feel free to offer corrections and/or curve-fitting
                              Edit: __ This looks pretty good to me; but I still don't know what it’s for sad
                              Edited By Michael Gilligan on 13/08/2021 22:24:22
                              #558203
                                The non-linear scale implies the gauge is for measuring intensity rather than a physical dimension, and the peep hole and squared top suggest a simple optical assembly is missing.
                                As the instrument is a pocket tool, it's used by someone walking about. The peep hole suggests she eyeballs the target. Sound and light, hence heat, are perceived by humans on a logarithmic scale. I think it's for judging the temperature of a furnace or flame for making glass, normalising steel, welding, or melting without boiling etc. Possibly confirming a lighting system is performing to specification.
                                Any sign of anything mechanical missing at the top? If it's a visual intensity gauge I'd expect the control wheel to adjust an aperture between the peep hole and the lens carrier, now lost.
                                Martin King 2
                                  @martinking2
                                  Hi All,
                                  Thanks for the helpful comments.
                                  Does anyone want it? FOC and free postage!
                                  Cheers, Martin
                                  #558214
                                    Posted by Martin King 2 on 14/08/2021 11:06:29:
                                    Hi All,
                                    Cheers, Martin
                                    I would love to explore it further, Martin
                                    Martin King 2
                                      @martinking2
                                      Hi Michael,
                                      It will be in the post to you on Monday morning. Please email me your address again as I seem to have mislaid it! blush
                                      Cheers, Martin
                                      #558222
                                      pgk pgk
                                        @pgkpgk17461
                                        SOD,
                                        I was speculating that the square held the base of a tool that was snapped into place into your 'aperture'. Something like fixed and sprung divider arms as a quick sizing of some tiny items for consistency…
                                        The attachment would be kept in a separate pouch.
                                        But since evidently the arms are easily bent it's an odd choice of design for any real accuracy.
                                        pgk
                                        #558242
                                        Steviegtr
                                          @steviegtr
                                          Never mind. I am sure Michael will google it to death & surprise us all with it's use. Mnn.???.
                                          Steve.
                                          #558244
                                            Posted by Steviegtr on 14/08/2021 18:04:20:
                                            Steve.
                                            Sorry Steve,but it has to be said :
                                            I am sick of people assuming that I just 'Google' everything.
                                            What I wrote was :
                                            "I would love to explore it further"
                                            … and you will see that I have already put quite a lot into the exploration.
                                            PLEASE just give it a rest
                                            Steviegtr
                                              @steviegtr
                                              Posted by Michael Gilligan on 14/08/2021 18:31:15:
                                              Steve.
                                              What I wrote was :
                                              Michael you have taken my post completely out of context. I was praising you for finding things that we rarely do. I always read your posts with great interest. If i seemed to offend it was not meant that way.
                                              Steve.
                                              #558275
                                                Posted by Steviegtr on 14/08/2021 23:21:24:
                                                Steve.
                                                O.K. Steve … let’s just say your comment touched a raw nerve.
                                                yes MichaelG.
                                                #558276
                                                Steviegtr
                                                  @steviegtr
                                                  Posted by Michael Gilligan on 14/08/2021 23:44:13:
                                                  Steve.
                                                  yes MichaelG.
                                                  Michael i think you underestimate yourself. I have the impression that you are highly regarded on this forum. At least i look up to you. I did the item to death & came up with nothing. I really do hope you find what it is.
                                                  My Uncle worked at a nuclear plant in Cumbria some years ago & had a similar device , which he always kept in his top pocket. It was to make sure that any area he entered was not radio-active. I followed that path & found nothing. Hope you do better.
                                                  Steve.
                                                  #558277
                                                  duncan webster 1
                                                    @duncanwebster1
                                                    That would be a quartz fibre dosimetry, getting to be old hat when I was regularly visiting Sellafield, and that's a fair few years back. It's all done electronically now. I only had one scary moment, alarm went off continuous rather than the occasional beep. Turned out the battery was nearly flat. I don't glow in the dark
                                                    Edited By duncan webster on 15/08/2021 00:59:08
                                                    #558281
                                                      Posted by Steviegtr on 15/08/2021 00:00:45:
                                                      Michael i think you underestimate yourself. I have the impression that you are highly regarded on this forum. At least i look up to you. […]
                                                      Thanks for the positive thought, Steve … but the fact is: I have, in the past, suffered some extremely hurtful personal comments from individuals on this forum.
                                                      Let’s just leave it at that, please.
