Unknown thread
Unknown thread
Home › Forums › Workshop Tools and Tooling › Unknown thread
  • #473401
    Mike Armitage
      @mikearmitage
      I've been sorting my taps during lockdown. I’ve come across 3/8th 26 tap. It’s British made. Anyone know what thread it is? Cycle thread?
      #19763
      Mike Armitage
        @mikearmitage
        #473412
        Sakura
          @sakura
          Cycle or Brass depending on thread angle
          #473467
          Bo’sun
            @bosun58570
            If it's a "cycle thread", I'd be interested to know where it went. It might be an old deraillier mounting screw (M10 x1 today). Too small I think for a pedal thread. !/2" & 9/16" UNF If I remember correctly.
            #473471
            Maurice Taylor
              @mauricetaylor82093
              Cycle thread was also used on British motorbikes in 1960’s and before that.
              #480778
              peter smith 5
                @petersmith5
                All brass threads are 26 tpi exactly the same as ME threads and same thread of 55 degrees as they are British standard.
                #480896
                Howard Lewis
                  @howardlewis46836
                  Cycle threads (CEI ) are 60 degree angle.
                  #480911
                  Emgee
                    @emgee
                    Old models cycle front wheel axle size, 5/16"x26TPI, just making a shaft with an M8x1.0, so close difficult to tell the difference with thread gauges.
                    Emgee
                    Edited By Emgee on 19/06/2020 16:16:02
                    Edited By Emgee on 19/06/2020 16:16:47
                    #481065
                    stevetee
                      @stevetee
                      Posted by Emgee on 19/06/2020 16:15:17:
                      Emgee
                      The cycle thread would have a rounded crest, the metric would have a truncated crest.
                      #481067
                      stevetee
                        @stevetee
                        Emgee
                        The cycle thread would have a rounded crest, the metric would have a truncated crest. An older cycle rear spindle would have been 3/8"x26tpi, more modern ones will be metric. Just as an aside, the hardware shop in Lampeter still has in stock BSF and Whitworth bolts.
                        #481287
                        larry phelan 1
                          @larryphelan1
                          Whitworth bolts are very hard to get over here [Ireland ], I had to make some for a friend to repair his old farm equipment. Just as well I have a collection of Whit and B,S,F taps and dies, never know when they might come in handy.
                          #481292
                          Bo’sun
                            @bosun58570
                            Concur rear axle cycle thread.
                            #481296
                            old mart
                              @oldmart
                              The Cycle threads are indeed a strange mixed bunch, there is a 7/16 X 20 one which is so close to 7/16 UNF that you would have to use an optical comparitor to tell apart.
                              Howard Lewis
                                @howardlewis46836
                                Rounding and truncating the crest of the thread have the same objective; to prevent interference between the crest of then thread on one part and the valley on the mating part.
                                For the likes of us, particularly when screw cutting, as opposed to using Taps and Dies (which should do the job for us ), truncation is the easiest method. (IF I search long enough, I could find my Apprentice Training Notes which give the formula to calculate how much to truncate any UNF thread )
