The cheapest way to make a tailstock Dro
Home › Forums › Workshop Tools and Tooling › The cheapest way to make a tailstock Dro
  • #520322
    Steviegtr
      @steviegtr
      I wanted a Dro on the tailstock of the Myford so i could get an accurate way of drilling a hole in stock. I did not want to drill holes in the tailstock so if i wanted to remove it, i could without damage. This is on my Super 7 , but could be fitted to any lathe with a bit of thought. The cost was under £10 for the whole project.
      Steve.
      Tailstock Dro
      #20106
      Steviegtr
        @steviegtr
        My cheap Dro
        #520331
        gary
          @gary44937
          hi steve, nice video, is that you or the monkey that fills the ashtray.
          #520335
          not done it yet
            @notdoneityet
            Is this an installation of a digi-caliper using neodymium magnets?
            #520371
            Chris Evans 6
              @chrisevans6
              Great work. I put one of those Aldi callipers on my 14×40 lathe around three years ago. I did drill and tap the tailstock for my installation. Best £8 ever spent on the lathe, only just changed the battery for the second time.
              #520439
              Steviegtr
                @steviegtr
                Posted by gary on 17/01/2021 07:54:37:
                It's the monkey. I keep telling him, but will he listen.
                Steve.
                #520440
                Steviegtr
                  @steviegtr
                  Posted by not done it yet on 17/01/2021 08:04:42:
                  No , i did look at making it that way . It seemed to be too unstable. So the fixings are the 2 oil ports. So far it has been ok.
                  Steve.
                  #520448
                  old mart
                    @oldmart
                    Nice result. There are a couple of things to consider when doing a mod like this. The stainless steel can catch you out when drilling and tapping, it is prone to workhardening. I would recommend sharp drills, slow rpm and good feed rate to minimise the danger. Make any holes to be tapped on the loose side, not tight. With a self extracting quill taper, make sure there is going to be a conflict when clamping on a bracket to the end.
                    I had trouble drilling one of these hardened stainless readouts and had no option but to resort to a solid carbide drill to finish the hole.
                    #520472
                    Greensands
                      @greensands
                      img_0545.jpgHave attached some pics of my unit made up fro a 100mm long DRO skide from ARCEuro (I think) making use of the 2BA tapped holes provider for the oilers. It has given me excellent service.
