Hi Guys
Thanks for the replies, first off Tony you may have just answered my question “tungsten hardened” it does sound impressive doesn’t it and me not knowing too much about taps other than HSS being good, I just thought I’ll post on the forum to find out if they are any good but from the answers I’ve had so far I won’t be rushing out soon to buy some.
Jason thank you for taking the time to have a look on the bay, I will be taking your advice and yes sadly it’s the fine thread I need.
Can I pick your brain a little more, I’m still looking on the bay at a Volkel tap sold by almtoolandgauge, am I right in assuming by what it says (M12 x 1.25 V Coil – Fits Helicoil – Wire Thread Repair Insert Tap,) priced at £11.90, its only for helicoils.
Basically I’m after it to tap a hole in mild steel and fit a screw or bolt straight into it, no helicoil fitted.
Roger thanks for the link, at least I won’t buy any are UH-CT it’s such a drag having to send things back if the wrong item has been purchased.
