Stuart No 4
Stuart No 4
Home › Forums › General Questions › Stuart No 4
  • #626851
    Garry Coles
      @garrycoles69390
      Hello
      I'm building a Stuart No 4 and would like to know if a displacment lubricator can be fitted directly to the side of the valve chest. Or does it need to be connected to the steam inlet.
      I have seen other pictures of them fitted to the valve chest, but I wondered if it works OK.
      Happy new year fellow model builders.
      Garry
      #28974
      Garry Coles
        @garrycoles69390
        #626974
        DiogenesII
          @diogenesii
          bump
          #626975
          Garry Coles
            @garrycoles69390
            bump ???
            #626977
            Dave Wootton
              @davewootton
              Garry
              DiogenesII has thoughtfully bumped your thread up to prevent it from rapidly dissapearing down the list of postings where it would possibly be missed by many.
              Weary
                @weary
                Whilst I have not done this myself I cannot see any reason why a displacement lubricator fitted to the steam-chest should not (in broad terms) 'work' in providing lubrication.
                Jasonb may have some insight based on experience?
                Phil.
                Edited By Weary on 01/01/2023 08:50:56
                #626985
                  It was certainly done on full size, my Fowler has one though probably more of a backup if the mechanical pump fails than the main source of oil.. My personal thoughts are that it may be a bit less effective than the usual method of having the lubricator mounted via a tee in the steam feed.
                  With the tee as the oil is displaced it will flow into the line of fire so to speak and get carried with the steam and shot all over the valve and droplets will also be carried into the cylinder.
                  With it on the side of the steam chest I feel there is a chance that the displaced oil will just dribble down the inside wall of the valve chest and eventually find it's way onto the valve and into the cylinder.
                  These are just my thoughts and not actually been put into practice.
                  #627002
                  Garry Coles
                    @garrycoles69390
                    Thanks for the info on bumping & the postion of the lubricator.
                    Garry
                    #627031
                    Martin Johnson 1
                      @martinjohnson1
                      A small Stuart has recently passed through my hands, which had the displacement lubricator on the valve chest cover. It looked like it had seen a fair bit of use in that condition so I would say go ahead.
                      Martin
