Single phase or Inverter
Home › Forums › Beginners questions › Single phase or Inverter
  • #63316
    Peter Simpson 2
      @petersimpson2
      Hi Guy’s
      I have just aquired a nice Meddings powered hacksaw which has a 3 phase, dual voltage motor. I’m not sure if I should install an inverter as I have on my lathe and milling machine of change the switch gear to single phase. An inverter on a mechanical saw seams a little over the top. what do think ?
      Best regards
      Peter
      #5389
      Peter Simpson 2
        @petersimpson2
        Powered Hacksaw
        #63319
        Peter G. Shaw
          @peterg-shaw75338
          Hi,
          I understand that it is possible to use the same inverter for a number of machines by using a system of switching. After all, if you are a lone worker, you can only (safely) use one machine at once.
          Peter G. Shaw
          #63320
          John Stevenson 1
            @johnstevenson1
            Peter, seeing as a power hacksaw only needs a limited amount of power what about converting the existing 3 phase motor to run on single phase using a capacitor on the dead leg.
            True it will be derated but I’m sure that it will be powerful enough.
            All it will cost to find out is to rob a capacitor out of a scrap florry essence tube.
            John S.
            #63321
            John Haine
              @johnhaine32865
              Um, I don’t think fluorescent tubes have capacitors do they? Inductors, yes.
              #63322
              John Olsen
                @johnolsen79199
                The flourescents will have a capacitor too but I don’t think it would be up to the job.You want something more like you find on a motor, and it want to be continuously rated too.
                If you set the three phase motor up to run on single phase, you will get , in theory, about 2/3 of the power. Practically, what you will get is in my experience more than enough. I have an 18 inch shaper, one setup that I have tried with that limited it to a quarter of the nominal horsepower, eg 3/4 hp out of a 3 hp motor. You would be surprised how big a cut you could still take. I more usually run that machine with a single phase set up, without the starting capacitor. This means giving the pulley a suitable kick at the right moment. Running like that, eg nominally about 2/3 of the original power, it has taken a cut of 0.250 thou across a piece of cast iron bar. So lack of power is not usually a problem.
                regards
                KWIL
                  @kwil
                  Do you really mean 1/4 thou?
                  #63356
                  John Olsen
                    @johnolsen79199
                    Hi Kwil, ooops, I should engage brain first shouldn’t I. No that should have been 250 thou or 1/4 of an inch. The machine took that cut in its stride without the slightest sign of distress. I am not sure how much more it could take, it gets expensive finding it enough metal to feed it at those sort of cut sizes. Very handy when a big slab of metal needs cleaning up, and leaves a much nicer finish than a milling machine.
                    regards
