SIMAT 101 – Changing the belt?
Home › Forums › General Questions › SIMAT 101 – Changing the belt?
  • #27232
    Gra
      @gra
      #460143
      Gra
        @gra
        Hi Folks,
        Does anyone know how to remove the pulleys and shaft from a simat 101 headstock to replace the V belt, mine's worn thin and needs replacing.
        Cheers,
        Gra
        #460353
        James A
          @jamesalford67616
          I have the predecessor to the SImat, the Flexispeed II. The two machines are pretty much identical, apart from cosmetic details. To change my belt, I had to loosen the grub screw which retains the main pulley and the grub screws on the back gear. The spindle then pulls out so that you can get the old belt out and a new one in. You obviously have to thread all of the parts off and back onto the spindle.
          My original belt, which was new and fitted in the V grooves, more or less level with the top of the groove, slipped badly. I replaced it with a much wider one which stands proud of the grove, but grips perfectly. I can measure it if that helps.
          James.
          #460355
          Gra
            @gra
            Many thanks James.
            I have a new belt, just couldn't remember how the gearing came apart to fit it! All done and back up and running again.
            Graham
