Sharpening Carbide tipped tools
Home › Forums › General Questions › Sharpening Carbide tipped tools
  • #132758
    Paul Scholey
      @paulscholey17560
      I need to sharpen a carbide tipped lathe tool but dont have a suitable sharpening stone. I did buy a green silicone carbide stone from a well known dealer recently, no makers name on it, but found several cracks in it and got a refund., they are still being sold. My question is have diamond sharpening stones taken over now from silicone carbide stones? and I have been told they have to be used with water?
      Regards Paul.
      #22898
      Paul Scholey
        @paulscholey17560
        #132763
        Ian P
          @ianp
          I would say that diamond is the best way to sharpen carbide. I have only ever seen and used Diamond wheels dry but I use water on the diamond 'stones' that have many advantages over the traditional oilstones (although they are much favoured by craftsman woodworkers.
          So water not oil, for the hand held diamond files etc.
          Ian P
          #132764
            In the immortal words of the song:
            Diamonds are a Girl's best friend.
            [and also a Model Engineer's]
            Richard Marks
              @richardmarks80868
              Gentlemen
              The usual advice given is to use water with diamond stones but I have found that it can leave traces of rust from the metal that has been removed, I now use plusgas as a lubricant and have had no trouble since.
              Dick
              #132784
              Paul Scholey
                @paulscholey17560
                What I meant was the circular ones to fit on a bench grinder, are you talking about the hand held ones?
                I cant see it will be very good using a lubricant on a bench grinder?
                #132797
                Ady1
                  @ady1
                  Used a silicon carbide wheel for a long time now and never had a problem, most tools only need a brush up
                  Never used water with one, only dry
                  #132801
                  Thor 🇳🇴
                    @thor
                    Hi Paul,
                    I used a silicon carbide wheel to dress up carbide tools, and as Ady have not had any problems. I guess though that diamond wheels is the way to go, and I use a diamond hone to give of carbide tools a sharper cutting edge.
                    Thor
                    #132802
                    Russell Eberhardt
                      @russelleberhardt48058
                      The diamond wheels are good for light sharpening and give an excellent finish. If I have much material to remove I still use my green grit wheel.
                      Russell.
                      #132806
                      Paul Scholey
                        @paulscholey17560
                        Thanks for the reply, sounds like one of each might be best, what abrasive grade would you go for with the silicone and where can I buy a decent one from with a makers name on it thats not going to have cracks in it ?
                        #132810
                        Trevorh
                          @trevorh
                          Would it not be a good idea for someone out there to post a list of the types and colours of of the grind wheels and stones, I can never remember what is best for what, I am sure someone will know
                          #132811
                          RICHARD GREEN 2
                            @richardgreen2
                            ABTEC 0800 027 1928
                            I've used them, nice company , reasonable prices.
                            Richard.
                            #132838
                            donkey
                              @donkey
                              #132839
                              Thor 🇳🇴
                                @thor
                                Hi Trevorh,
                                Was this the kind of information you were looking for?
                                Thor
                                Edited By Thor on 16/10/2013 16:50:11
                                #132840
                                mechman48
                                  @mechman48
                                  Trevor / Paul
                                  Some info from my 'Universal Grinding Data Book'… may be helpful.
                                  Edited By mechman48 on 16/10/2013 17:29:07
                                  #132854
                                  Paul Scholey
                                    @paulscholey17560
                                    Thanks everyone for your help.
                                    #132885
                                    Trevorh
                                      @trevorh
                                      Morning Thor/Mechman,
                                      Thor I was thinking more along the lines of an "idiots" guide for example HSS use Pink grit wheel, for tungsten use Green and so on
                                      Mechman sorry but I can't get your link to work
                                      Thanks
