Scale narrow gauge locomotive
Home › Forums › Locomotives › Scale narrow gauge locomotive
  • #263288
    Ian Lee 4
      @ianlee4
      I am just planning the building of a narrow gauge Beyer Peacock Garratt, I have a full set of original drawings, The full size loco gauge is 2ft or 610mm, I want to scale the size to run on 5inch gauge, can anyone tell me what the scale should be, is it 1.0625 per inch ?
      The drawings are for a South African Railways 2ft gauge Garratt.
      #1564
      Ian Lee 4
        @ianlee4
        working out scale size for a Garratt
        #263297
        Perko7
          @perko7
          Scale would be 2.5inch/foot (2ft gauge gives 5inch gauge) or about 1/5 full size and ignore the inaccuracy in the gauge.
          I suggest you choose a scale that's easy to work with and modify any critical dimensions to suit. That's what i've done with a 3ft6in gauge loco for 5inch gauge which i am making at 1/8 full size or 1.5inch/foot scale. The scaled gauge works out to be 5-1/4 inches so my wheels are a fraction closer together on the axles than they should be, but as long as you design everything else to suit then it's not a problem. Model railway manufacturers have been doing it for decadeswink .
          #263307
          Ian Lee 4
            @ianlee4
            Thank you Geoff
            I was having a senior moment when trying to work out the scale, you have confirmed what I thought, I got 1/4.8 full size. I started drawing it from my plans then realised just how big it will be, thats when the doubt crept in. Its a 262-262 wheel layout, It works out that each set of frames will be 37 inches long, overall lenght will be about 11ft. Fortunately I do have room to build it and the machining capability although it is too long to fit on our club turntable.
            #263311
            Ian Lee 4
              @ianlee4
              It will be electrically driven as the boiler cost is to expensive even if I make it myself, I am in a lucky position in that one of my close freinds is a pattern maker and another friend has a non ferrous foundry so I can getting castings made quite easily.
              #263552
              Perko7
                @perko7
                That will be a pretty massive beast when finished! Should have tremendous pulling power too. One of the problems with modelling narrow gauge locos from the colonies is that they were generally built closer to standard gauge proportions, so when scaling to suit the gauge it ends up a big model. A standard gauge loco at 1:4.8 scale would be about 12" gauge. Good luck with your project.
                #299239
                Jon Cameron
                  @joncameron26580
                  Did this project idea progress any further, I'm a big fan of Garretts,and especially their sheer size in full scale, the narrowgauge loco will be one heck of a beast when builtsmiley
                  #299258
                  David Paterson 4
                    @davidpaterson4
                    There is a running full size one where I live – its huge
                  Home › Forums › Locomotives › Topics
