Hi Folks, Have been making some more toolholders for me qctp and as all the dovetails are now completed I have started to cut the 25mm slots for the toolshanks. Decided to try a cutter that I was given a while back to try. A Guhring RS 100F Firecoated solid carbide rougher, The difference in performance over a conventional 2 or 3 flute mill is staggering. The biggest benefit I think is the greatly reduced cutting forces, I found using a standard 2 or 3 flute my Lux mill [ not the K &T ] was good for about 2.5mm depth of cut in the EN 16t . With the new rougher 6mm was easy on the machine [16mm Ø ] AND a faster feed rate.
I had known about them long ago but had never bothered trying one until now. There is no going back to the plain types now for deep slots or squaring off rough edges. Light cutting and finishing then yes, I will stick to the plain old 2, 3 or 4 flute. Anyone else on here used them often [ the roughers ]
Cheers.
