removing ball oilers
Home › Forums › Workshop Tools and Tooling › removing ball oilers
  • #521176
    grimme
      @grimme
      ive got a 70's student with broken ball oilers is there a way of removing them without drilling because of swarf ?
      #20115
      grimme
        @grimme
        #521182
        Hopper
          @hopper
          Screw a PK screw in the hole in the top of the oiler and lever it out with nail pulling pliers etc or a slide hammer or even a stack of washers under the head of the screw as you tighten it down.
          #521186
          not done it yet
            @notdoneityet
            Search ‘oilers’. Read applicable threads, particularly the ‘press button oilers’.
            #521215
            Brian Wood
              @brianwood45127
              Hopper has it right, the method works without generating any debris
              #521231
              Bo’sun
                @bosun58570
                I've used screw extractors to good effect. A magnetic pick-up tool can be useful to make sure there isn't any broken spring in the hole. Any brass swarf might be a little more difficult, although tiny spoon ended dental picks can come to the rescue.
                #521269
                Ady1
                  @ady1
                  Sometimes you can just tap a small screwdriver under the lip and lever them out
