piston rings
piston rings
Home › Forums › Workshop Techniques › piston rings
  • #358502
    Philip Burley
      @philipburley44197
      How could I reduce the thickness of a piston rings from 3./16 to 1/8 inch with out a proper grinder
      regards
      #16019
      Philip Burley
        @philipburley44197
        #358505
        Jeff Dayman
          @jeffdayman43397
          glue to temporary faceplate / faced bar end with good superglue CA glue, fill ring end gap with CI scrap 3/16 thick
          mount temporary faceplate in lathe chuck
          CAREFULLY with VERY light cuts face to 1/8" thick
          mount Dremel-like motor tool in toolpost, with fine grit grinding wheel grind ring face smooth.
          Do not let ring get hot at any stage, or ring will detach.
          After finishing the ring detach glue with water and low heat.
          Tricky, but I have done a few that way when there is no alternative.
          #358527
          not done it yet
            @notdoneityet
            If doing as above, I would be doing it “belt and braces” by fitting the ring(s) into a 1/8” jig to emulate piston and cylinder.
            The last time I had a similar problem I increased the ring gooves on the piston, but the difference on the rings and grooves were 1.50 and 2.00mm.
          Home › Forums › Workshop Techniques › Topics
