Paddleduck cylinder bore query
Home › Forums › Beginners questions › Paddleduck cylinder bore query
  • #75070
    Andrew Evans
      @andrewevans67134
      Hello all – any advice would be much appreciated. I am making Bogstandard’s paddle duck engine, remaking the main cylinder block at the moment using brass rather than CI. My question is for the 2 10mm cylinder bores I cannot decide whether to bore with a boring head in my Cnc milling machine or use the nearest sized reamer I have which is 3/8″ (9.5mm). Is reducing the cylinder diameter going to have much effect on the running of the engine? If I do use the boring head can anyone give any tips – I always struggle to get the bar rotated in the right way and the head lined up with the drilled hole – if that makes sense?
      The main reason I am remaking it is that the cast iron off-cut I found proved to be full of inclusions and really hard. The surface quality of the bores was too rough I decided and no end of honing and polishing seemed enough. Went for brass instead.
      Thanks in advance. Andy
      #5663
      Andrew Evans
        @andrewevans67134
        #75080
        Bogstandard
          @bogstandard
          Andrew,
          I designed this engine so that you can do what you suggest, change sizes or materials to suit what you have available.
          Brass will be fine for the cylinder, as will your 3/8″ reamer.
          All you will need to do is to resize the pistons, top cylinder cover and gland end cover to suit the bore.
          The engine will run fine with with the new sizes.
          Hope this helps
          Andrew Evans
            @andrewevans67134
            Many thanks John. I have used a drill and honing to finish the bores now and they seem fine.
            Can I also say that I really appreciate the effort you went to to produce the book originally – for someone lIke me it’s invaluable.
            Andy
