One Sided Fastener
One Sided Fastener
Home › Forums › The Tea Room › One Sided Fastener
  • #417712
    Vic
      @vic
      New to me!
      It seems like some other conventional fasteners now also use the five lobe design.
      #35535
      Vic
        @vic
        #417718
        ChrisB
          @chrisb35596
          Similar to fasteners used on aircraft. The key design looks much better than the Hi-lock hex drives which have a tendency to round off – meaning you have to drill out a titanium fastener in some awkward place and position!
          #417719
          John Haine
            @johnhaine32865
            The mounting brackets for the "movable vehicle-activated signs" (a/k/a speed warnings) we use round our villages are fixed to speed limit sign posts using jubilee clips that have a 7-sided socket screw!
            #417796
            old mart
              @oldmart
              The Hi Lock that I used had the aluminium snap off heads on the nut, the hex socket was only needed in case the bolt rotated while the nut was tightened, not to unscrew the assembly. I believe there are more conventional nuts for certain applications.
              Theft of aluminium road signs, cast iron manhole covers and bus bars from electricity substations is common these days. Probably getting less as China is cutting back on its scrap metal imports, so the price is dropping.
              #417805
              Vic
                @vic
                Posted by John Haine on 07/07/2019 12:09:31:
                Mole grips on the outside of the screw?
                #417807
                ChrisB
                  @chrisb35596
                  Posted by old mart on 07/07/2019 19:59:54:
                  Depends, when using Hi-Locks in structural parts and repairs most of the times it's an interference fit, so the hex drive on the collar most often than not snapped off before the fastener could turn – given that the hole was reamed to the correct size beforehand.
                  Where hi-locks are used to retain brackets floor beams etc hex nuts are used not collars. Sometimes the fastener rotates with the nut and then you'll need the key.
