Oils.
Oils.
Home › Forums › General Questions › Oils.
  • #121912
    Alan .204
      @alan-204
      I have a couple of questions today regarding the use of different oils I would like to know what kind of oil is recommended for a Colchesrter Bantam lathe and also a Centec 2B Mill, that's the first question the second is about cutting oils, I currently have a drip feed to both machines but eventually i would like to fit a coolant pump to both, its the soluble oil I use but both machines seam to cut better and it seams easier on the machines if I apply normal cutting oil with a brush, so would you pump a different type of oil than the soluble type if so what would you use, thanks in advance.
      Regards Alan.
      #22659
      Alan .204
        @alan-204
        #121917
        Thor 🇳🇴
          @thor
          Hi Alan,
          if your headstock bearings is lubricated with oil, a socalled "hydraulic oil" with an ISO VG of 32 could be used (Shell Tellus, Esso Nuto etc.). I assume you use a "slideway oil" like Shell Tonna (ISO VG 68) on the ways?
          Thor
          #121933
          Ian S C
            @iansc
            For your pumped cutting fluid, soluble oil is the way, if you use coolant with carbide tooling, you either flood the work, or work it dry, although I some times use the soluble oil undiluted. Ian S C
