Mystery object
Mystery object
Home › Forums › The Tea Room › Mystery object
  • #427981
    Mikelkie
      @mikelkie
      What are these wires used for?mystery objects
      #35608
      Mikelkie
        @mikelkie
        Wire in drawers
        #427982
        Mikelkie
          @mikelkie
          mystery objectsmystery objects
          Edited By Mikelkie on 07/09/2019 22:11:05
          #427983
          Mikelkie
            @mikelkie
            mystery objects
            #427988
              Looks like a stock boxes for a seller.
              'Piano' wire is very hard and can be brittle if bent too far so it furtehr work hardens, good for pivots and pins and some springs.
              Iron wire is soft and easily bent to shape.
              I imagine the 'hard steel wire' is intermediate.
              Cornish Jack
                @cornishjack
                Much used in model aircraft , for push-rod ends and similar. Almost anything requiring thin high strength – lantern pinions for clocks maybe? Very useful stuff, particularly as you appear to have a number of different gauges.
                rgds
                Bill
                #428067
                old mart
                  @oldmart
                  Swedish made top quality steel. The iron wire is commonly used for holding things together while they are being brazed or silver soldered. The piano wire and the hard steel would be of interest to horologists
                  #428080
                  larry phelan 1
                    @larryphelan1
                    I seem to remember that Hitler used piano wire to strangle people he did not like.
                    I suppose it has other uses as well.
                    #428085
                      Wild guess – part of a piano repairman's outfit. As the wires all appear to be the same size, I'm thinking of the rods that connect piano keys to their hammers. Three grades of rod giving different degrees of spring might be handy for adjusting how the hammer whacks the strings.
                      Martin Hamilton 1
                        @martinhamilton1
                        Piano wire is also what they use to run tethered cars & hydroplanes on, very strong wire indeed but must be looked after re even the slightest kink in the tether wire must be replaced. Needs to be strong when a 16 lbs flash steam hydro is running at over 130mph & an electric tether car is running over 220 mph.
