Myford ml10 chucks
Myford ml10 chucks
Home Forums General Questions Myford ml10 chucks
  • #549829
    Jeremy Smith 2
      @jeremysmith2
      Are there any users on here that run a 125mm chuck on their myford ml10? What kind of drawbacks have you encountered?
      I was running a 100 mm chuck on my unit, but only had one set of jaws (internal ones), so I was always limited on how large of an item I could hold. What’s the largest size you can hold comfortably, with a 100 mm chuck, with outer chuck jaws? How about for a 125 mm chuck ?
      #28221
      Jeremy Smith 2
        @jeremysmith2
        100 mm or 125mm chuck for myford ml10
        #549831
          It doesn’t directly answer your question, Jeremy … but you may find this illustration useful:
          Pratt Burnerd Hard Outside Jaws
          Clive Hartland
            @clivehartland94829
            The ML 10 is not a gap bed lathe and I would think that if a 125 mm diia. chuck was used then you would have impact on the bed when using the outside jaws for large dia. jobs.
            I find my 100mm chuck more than adeqaute for what i do..
            #549888
            old mart
              @oldmart
              The bigger the chuck, the longer the body, so you would loose some bed length. Check out the three jaw offerings on the ARC site, they helpfully show the sizes and their holding capacity.
              #549928
              Clive Hartland
                @clivehartland94829
                I have just measured the gap between the 100mm chuck and the lathe bed, 30mm. The difference between 100mm and 125mm chucks means that you endup with about 17mm clear for the bigger one.
                #549930
                old mart
                  @oldmart
                  When there is not much gap between the chuck body and the bed, the advantage of the larger chuck diminishes. Also the cross slide is likely to foul the chuck body.
