Myford Connoisseur Lathe
Home › Forums › Beginners questions › Myford Connoisseur Lathe
  • #71959
    Steve Talbot 1
      @stevetalbot1
      Hi,
      Can anyone tell me if a METRIC Myford Connoisseur lathe has an imperial 8tpi leadscrew and if so does a metric conversion quadrant and gears have to be used to cut metric threads?
      If a quadrant is required is this identical to that used on an imperial Super 7B to cut metric threads?
      Any information would be appreciated.
      #5588
      Steve Talbot 1
        @stevetalbot1
        #71966
        Sub Mandrel
          @submandrel
          If it has an 8tpi leadscrew you only need a 63-tooth changewheel to be able to do metric threads.
          Steve Talbot 1
            @stevetalbot1
            Thanks for replying Neil,
            Would a metric quadrant be necessary on a metric connoisseur?
            Steve
            #71975
            chris stephens
              @chrisstephens63393
              Hi Steve,
              When I was first demonstrating on a “Metric” Myford at recent MEXs, I found it surprising that although the dials were metric the gearbox was still in TPI. Should one have seen the writing on the wall, that Myford could not afford to design and make a Metric gearbox?
              If Myford had not been so cash strapped, and perhaps also stick-in-the-muds, maybe they could have offered an ELS (electronic lead screw) for their machines, which would have made the IMP/Metric issue redundant.
              chriStephens
              #71976
              John Stevenson 1
                @johnstevenson1
                Steve,
                To be perfectly precise on the pitch then the answer is yes, you need the whole banjo and gears.
                If you aren’t working for NASA then you can get away with using a 33 or 34 tooth gear as the input and still keep the fine feed etc.
                The 33 / 34 combination will do all common threads with only a slight error, probably not enough to be measurable in the home shop.
                Simples ?
                John S.
                #71990
                DMB
                  @dmb
                  I believe that SMEE used to have a Myford on loan to them for their MEX stand but M now gone, so what now? Presumably a member will bring his along.
                  #71992
                  chris stephens
                    @chrisstephens63393
                    Hi John,
                    Indeed that was true but, now that they have gone, don’t forget that ArcEuro kindly gave us a fully kitted Mini-lathe which we take to shows. At some of those shows we can even let beginners have a bit of hands on experience. Isn’t that right Diane, I hope the kids enjoyed it.?
                    If one of the pre-owned machine dealers, who are going to Sandown this year, want to have one of their lathes demonstrated I am sure we could oblige.
                    chriStephens
                    #71993
                    ady
                      @ady
                      A digital system would probbly be better, especially when you need high accuracy.
                      Just cycle from imperial to metric as required.
                      An independent DRO would also take any backlash on the leadscrew nut into account and compensate for any additional wear in the centre of the leadscrew.
                      You could even measure the threadcutting tpi result of your machine down to around a hundredth of a millimeter, 5/10,000ths of an inch.
                      #71997
                      Steve Talbot 1
                        @stevetalbot1
                        Thanks for everyone’s comments, so it looks like the METRIC Myford Connoisseur lathe does need a metric banjo and gears.
                        But, does anyone know if a metric banjo and gears from a Super 7B will fit the METRIC Myford Connoisseur lathe.
