Multifix Retracting Toolholder.
Home › Forums › Workshop Tools and Tooling › Multifix Retracting Toolholder.
Viewing 11 posts - 26 through 36 (of 36 total)
  • #177533
    Swarf, Mostly!
      @swarfmostly
      Hi,
      Please forgive me for posting off-topic.
      I have seen lots of pictures of this type of tool-post but they always have the tool-holder mounted. I've never had the opportunity to examine one, 'in the flesh', so I still don't understand how the tool-holder is attached to the tool-post.
      Please could someone lighten my darkness?
      The vertical corrugations on the front of the tool-post are reminiscent of a 1930s sea-side lido cafe's windows – are they decorative or functional?
      Best regards,
      Swarf, Mostly!
      #177535
        Posted by Swarf, Mostly! on 27/01/2015 21:41:10:
        Best regards,
        Swarf, Mostly!
        What a delightful image !!
        But: Here is the truth
        Edit: and here, a YouTube video.
        Edited By Michael Gilligan on 27/01/2015 21:59:03
        #177539
        capnahab
          @capnahab
          img_5194.jpgOk , the lido cafe bolts to the top slide and the curtains around it can be tightened by a cam pulling the toolholders corrugations (similar to the lido cafes corrugations) to mate with lidos ones this locking everything tight. These are hardened and ground. The lever operates the cam and when released it slackens the lidos surround such that it can be rotated and the toolpost corrugations can slide into a different position to mate with the lidos corrugations in a different position. – Handy for eg chamfering. see pics below, the cam outlined in green. s'that clear ?.
          #177569
            Beautifully over-engineered Cap'n
            Clive Hartland
              @clivehartland94829
              But lovely to use as they cover all the needs of a toolholder, multiple positions with good clamping and a system for any lathe.
              #177591
              Swarf, Mostly!
                @swarfmostly
                Michael and Captainahab,
                Thank you for your most gracious and informative replies to my post.
                I had one of those 'seconds after hitting the post button' fears – what if they think I'm taking the mickey when, in fact, my reference to 'lido cafe' windows' was just a bit of whimsy!!!
                I now understand how that pattern of tool-post works, it looks effective but it must be costly to manufacture?
                Best regards,
                Swarf, Mostly!
                #177617
                capnahab
                  @capnahab
                  You can take as much Mickey as you like.
                  Neil, ' over-engineered ', – its a concept I have struggled to understand. A bit like 'I couldnt care less'. Its a bit like saying don't use a scalpel for an appendicectomy because its over engineered, you could use a carving knife because it cuts and you can also use it on the sunday joint.
                  #177624
                  SteveI
                    @stevei
                    Hi,
                    Neil – I'll bight. Why is it "over-engineered"?
                    Steve
                    #177656
                      It's awfully complicated when I could get almost the same result by just making some extra ratchet notches in the bottom of my QCTP.
                      SteveI
                        @stevei
                        Posted by Neil Wyatt on 29/01/2015 09:47:47:
                        Neil, I think that your "almost" caveat is the whole point. Can you get a design that is simpler that gives you equal or better result? (result for our purposes being, rigidity, and repeatability of tool location etc etc)? If so I very much look forward to reading about it. For reference I am currently thinking about a solution for my shaper to cut the splines to make my own A sized blanks.
                        Steve
                        #299481
                        Joseph Noci 1
                          @josephnoci1
                          I know this was discussed herein a while back, but it seems the KOMET threading inserts for the Multifix retractable tool holders are becoming very difficult to obtain. The Multifix holder uses a KOMET FG(1,2,3..) insert and I cannot seem to find a source able to supply 'individuals' anywhere – USA KOMET are stuck up and just don't respond! German KOMET seem to not ship to Africa…
                          The ( previously proposed) Ifanger inserts do NOT fit the Multifix holder – the serrated teeth that comprise the grip are much coarser, and Ifanger's response to a query – No, you cannot use our inserts in that holder.
                          Does anyone know of a Insert source that works??
                          Even Nina at Create Tool, the Chinese mnfr of the Multifix post and holders has had little luck on my behalf!
                          I am aware of the hacks people have implemented. welding on a conventional insert head, etc, but nothing cuts as nicely as a really sharp HSS KOMET insert when threading..
                          regards
                          Joe
