ML7 toolpost – Turns Under Load
Home › Forums › Workshop Tools and Tooling › ML7 toolpost – Turns Under Load
Viewing 25 posts - 26 through 50 (of 119 total)
  • #506894
    Rod Renshaw
      @rodrenshaw28584
      Dr GMJN
      Hmm… perhaps I was being rather dogmatic, sorry about that.
      Perhaps Myford changed the design from time to time.
      On my 1980s vintage Super Seven the grub screws are only 1/4" long and they do not engage with the flange of the toolpost. The exploded parts diagram of my handbook gives the Part Number for the grubscrews as MY2811 and specifies them as 1/4" x 2 BA, and as i have had this lathe from new I am sure they are original.
      The ratchet of my 4 way toolholder came with 1/2" long countersunk head screws and instructions to remove the grub screws and use the longer screws to secure the ratchet. The ratchet is 1/4" thick so the longer screws also do not engage with the flange of the toolpost.
      I also have a 1960s(I think) vintage ML7 which has had many owners and the grub screws on that are missing altogether, but the toolpost seems quite firmly fixed. I can't find the handbook but the arrangement seems very similar to the Super 7.
      Or perhaps
      If your grub screws are longer and do engage with the flange, I wonder if this is a modification done by a previous owner perhaps because he/she had lost the original grub screws or perhaps because the toolpost had become loose- otherwise I can see no need for the pin to prevent rotation of the flange/ post. The pin is shown clearly as Part Number 75/1411 on the exploded diagram of the Super 7 so I think it is fairly certain that the pin is intended to be there.
      What do you think?
      Rod
      #506906
      Dr_GMJN
        @dr_gmjn
        Rod, I don’t know. There is an ML7 toolpost modification video on YouTube, and the post flange looks to be drilled exactly like mine. My assumption was they’d separated the rotation constraint (pin) and the vertical constraint (screw threads) so as to avoid loading the grub screws such that they might try to ‘cam’ out of their holes under rotation of the flange. May well be wrong. On mine I had to tap the post out with a hammer. The entire inside of the casting along with the flange appeared to have been painted great after assembly. The paint flaked off the interface on disassembly.
        ETA my ML7 is 1966. I doubt very much that the post would ever have dropped on its own. It took a decent few whacks with a copper hammer to loosen it.
        Edited By Dr_GMJN on 11/11/2020 22:44:33
        #506942
        larry phelan 1
          @larryphelan1
          The toolpost on my lathe clicks in and locks in any one of four positions.
          I thought all toolposts were like that ??surprise
          #506953
          Rod Renshaw
            @rodrenshaw28584
            Dr GMJN
            Bit of a mystery then.
            It sounds very much as if your lathe's toolpost has not been disturbed or loose since the lathe was built and painted so it's not clear why anyone would feel the need to modify it's fixings. Perhaps some Myfords were built like that.
            When I thought your toolpost might have become loose and then been fixed it occurred to me that perhaps the toolpost was not secured precisely vertically and that might lead somehow to the the loosening toolblock. That now seems unlikely, but perhaps worth checking anyway?
            Good luck with the lathe anyway, they are good solid machines of their type and size and with reasonable care they outlast several generations of users.
            I have never heard of one like Larry's and I can't think why that would be useful, unless Larry is referring to what we might think of as a tool block or holder rather than the post (It's only a bolt really) on which the block or holder rotates. Perhaps Larry will explain.
            Rod
            #506960
            Anonymous
              Posted by Rod Renshaw on 12/11/2020 10:21:29:
              I have never heard of one like Larry's and I can't think why that would be useful……
              My lathe has a sort of dog clutch under the toolpost:
              In conjunction with a mating plate under the 4-way toolpost it allows one to index the toolpost every 9°. It's a really useful feature:
              • When parting off I know the toolpost is perpendicular to the lathe axis without needing to measure and the tool is not going to move whatever the cut.
              • For non-critical chamfers it's easy to lock the tool at a convenient, but repeatable, angle
              • When reseting the tool from chamfering, accurate positions on the dials are maintained, at least to a thou or so
              #506988
                The one I made while at school for my Unimat had a similar arrangement to Larry, The 4-way post sits on a plate that has 4 shallow holes, the post has a hole with a chamfered and sprung pin so as you turn the post round (one direction only) the pin will index it 90deg.
                The Multifix type being discussed elsewhere have a similar arrangement to Andrews and I have also see a ratchet type arrangement that has a sprung pin coming in from the side.
                #506989
                Howard Lewis
                  @howardlewis46836
                  My ML7 with a 4 way toolpost had a 4 tooth ratchet attached to the Top Slide into which a spring loaded pawl (Mounted horizontally, from memory, within the body of the 4 way toolpost ) engaged to prevent rotation.
                  #507035
                  Rod Renshaw
                    @rodrenshaw28584
                    I think we may have a confusion of terminology here.
                    Myford call the bolt on which their 4 way toolholder (or quickchange toolholder block) rotate the "Toolpost". It is fixed into the topslide casting, and it's really just a pivot, plus a way of securing the actual toolholder once it has been rotated.
                    The last 3-4 posts seem to be referring to what Myford call " toolholders" rather than the pivot bolt itself – which Myford calls a "Toolpost". Most of this thread has been dealing with a Myford lathe problem so we have been conversing in "Myfordspeak"
                    I think that's right, and hopefully a bit clearer!
                    Rod
                    #507049
                    Howard Lewis
                      @howardlewis46836
                      I took the words "tool post block" to mean the four way toolpost, as did several others it seems, judged by the comments on the ratchet wheel under the toolpost.
                      Sadly, I have seen two instances of Myford fourway tool posts being sold without the ratchet wheel, spring and pawl.
                      Which is what it seems has happened to the OP.
                      For what little comfort it may be my far eastern lathe has a positive stop system to resit cutting forces. BUT if the Toolpost, rather than the Top Slide, is set at angle for, say, a quick and nasty narrow chamfer, it does not move if clamped securely.
                      Lacking the ratchet and pawl, may I suggest checking that the clamp is not bottoming out and limiting the applied force, on the 7/16" stud and nut?
                      A few minutes checking and modifying may improve matters, as long as 0.250" a side cuts with a high feed rate, and a blunt tool, are not being attempted. It is a ML7 not a 21" Dean Smith and Grace.
                      Edited By Howard Lewis on 12/11/2020 17:46:28
                      #507065
                      Dr_GMJN
                        @dr_gmjn
                        Posted by Andrew Johnston on 12/11/2020 10:54:47:
                        Andrew,
                        That's exactly what I'd be looking for: Allows solid location, but also allows some incremental rotation to orient tools to clear existing part geometry or tailstock centres or whatever. Never seen one for an ML7 though.
                        Thanks.
                        #507071
                        Dr_GMJN
                          @dr_gmjn
                          Dr GMJN
                          Rod
                          Rod,
                          Actually no, you're right: I stripped it all down again just now, and the grub screw holes in the casting are drilled and tapped as I said, through the depth of the face and partially on the counterbore interface, but the tool post "spigot" flange is NOT threaded. So I was wrong – the grub screws play no part in securing the spigot either axially or in rotation.
                          Apologies – the frequency at which what I thought I remembered is at odds reality is definitely increasing.
                          #507077
                          Dr_GMJN
                            @dr_gmjn
                            So this might explain things better
                            Toolpost in-situ:
                            Removed:
                            I wonder if the unused hole was meant for a locking pin? There's obviously no corresponding hole in the casting, and unless there was an array of holes, I'd be stuck with a limited number of positions, which isn't really what I want.
                            So as suggested I applied some blue, and clamped it down (without turning it). Seems like it's only conatcting over a small area:
                            Strange becasue I can't get either part to rock on the surface plate. Maybe there's some pull-up effect going on when it's tightened.
                            I guess back to the wet and dry…
                            Not sure why the photos are rotated at random.
                            #507109
                            Howard Lewis
                              @howardlewis46836
                              Ah, a QCT, but a pretty badly battered combination.
                              The fact that cutting forces move it says that the clamping force between the Tool Holder and the Top Slide is insufficient.
                              Given the condition of the surfaces, that is not surprising, since the contact areas are greatly reduced.
                              Ideally, both surfaces should be ground or machined to clean up and get rid of the damage.
                              The least that I would try to do is to strip the Top Slide (Being Cast Iron ) and machine the surface flat to get rid of the dents. If the central bush is proud, that will also get rid of it standing proud.
                              If you don't have a mill. with some ingenuity, you could possibly mount the Top, Slide on a Faceplate, or possibly even in the 4 jaw, and machine it flat again. But it must be clocked level,as far as you can, given the deep indentations.
                              Maybe carefully gluing a shim to it,l to cover the many dents may help clocking?
                              Once clocked level, you take light cuts with a slow feed, with a HSS tool until the surface is acceptably clean.
                              Being cast iron, it will be a dirty job. Place a magnet beneath some newspaper under the chuck in the hope of collecting some of the swarf.
                              The Tool Holder may be hardened , in which case you have a long time to spend grinding it flat on emery on a surface plate.
                              Does that bush around the central post stand proud of the Top Slide, even by a thou or two? If it does, it may be bearing a lot of the clamping force applied by the handle.
                              If you do want, or cannot restore the surfaces, you will have to resort to bodge methods.
                              Even if you have to use a grinding point in a Dremel, it might be worth putting a chamfer around the hole in the tool holder, to prevent any interference.
                              Failing that, you could interpose some thin soft material (Copper, Brass or Aluminium shim ) between the Top Slide and the Tool Holder. Hopefully, being soft, when clamped it will be deformed to fill the many indentations in both. But having undamaged faces would be preferable.
                              In the past, someone has neglected and abused the machine, and you have to deal with that to have it behave as it should..
                              However you go about it, the centre height of the tool will, need to,be reset, either to take account of the Tool, Holder being lowered by the remachining processes, or raised by the shim interposed between the scored and dented surfaces.
                              Which method are going to adopt?
                              Hopefully, after all the hard work, you will have moved it from a total sow's ear nearer to being a silk purse.
                              #507121
                              Dr_GMJN
                                @dr_gmjn
                                Thanks Howard. It’s actually only the casting that’s pitted – the tool holder is pretty much perfect (I bought it when I got the lathe). It looks bad because the blue has transferred all the casting imperfections, that’s all.
                                There’s no bush to stand proud – the column doesn’t rotate. What you’re seeing is where the chamfer around the toolpost hole hasn’t transferred any Blue to the casting around the pin.
                                The tool holders are knurled for height adjustment, and locked with a caphead bolt. I routinely adjust tool heights if I change insert types or if I have to swap tools and have run out of holders.
                                I’ve got a mini mill, so I’ll probably fly-cut the cast surface and be done with it.
                                #507175
                                Dave Halford
                                  @davehalford22513
                                  Strange because I can't get either part to rock on the surface plate. Maybe there's some pull-up effect going on when it's tightened.
                                  Can't help thinking that the post might not be straight. Is it better without the top sleeve washer ?
                                  #507191
                                  KWIL
                                    @kwil
                                    I have identical QCTP blocks used on my Super 7 and ML7 lathes. Mine do not rotate under load even on my homebuilt topslides (GHT retracting etc) so it must be down to the poor surface on the OP's topslide. Clamping nut does need to be tight.
                                    With the OP's topslide bolted to an angle plate, it might be possible to flycut a decent surface using his lathe, or indeed his mini mill..
                                    Edited By KWIL on 13/11/2020 10:50:50
                                    #507196
                                    John Haine
                                      @johnhaine32865
                                      Yes, the unused hole is for a locking pin, you would need to drill and ream a matching hole in the topslide.
                                      #507231
                                      duncan webster 1
                                        @duncanwebster1
                                        Your local garagiste will know someone who skims cylinder heads. My local chap has a surface grinder and does little jobs like this for not a lot of folding currency/
                                        #507245
                                        Dr_GMJN
                                          @dr_gmjn
                                          Posted by duncan webster on 13/11/2020 15:08:23:
                                          Thanks Duncan.
                                          Is there anything particulary wrong about fly cutting it? I can do that myself on the mill – it's only a small area, and seems pretty straightforward on cast iron?
                                          #507248
                                          Rod Renshaw
                                            @rodrenshaw28584
                                            Dr GMJN
                                            No problem, not always easy to see inside these smaller assemblies.
                                            I use a Myford QCTH on both my Super 7 and ML7 sometimes and they do not rotate unexpectedly. I don't use a locking pin. I don't remember one being supplied by Myford with the QCTH, or a pin being mentioned in the literature, though I understand they are used on some lathes.
                                            If you can re-surface the topslide surface, and the toolblock if needed, I think you will find that there will be enough friction to resist unwanted rotation in normal use.
                                            A pin is all very well, and would definately prevent rotation but I think I would find it restrictive, sometimes I need to rotate the block just a little to get the tool into an odd corner.
                                            Rod
                                            #507256
                                            Dr_GMJN
                                              @dr_gmjn
                                              Thanks Rod. Yes, I’d rather retain the infinite adjustability. I wonder if roughening you the underside of the block might help? Just abrading the surface with some coarse wet and dry on a surface plate?
                                              #507286
                                                With fly cutting it's very easy to leave the surface concave if the mill isn't trammed perfectly. Personally I'd use a smaller endmill, say 10-13mm, run nice and fast. It should be as quick as flycutting, the finish might not look as pristine but will probably be just as smooth and the overall flatness will be significantly better if there is any out of tram.
                                                Ramon Wilson
                                                  @ramonwilson3
                                                  Posted by Neil Wyatt on 13/11/2020 19:24:57:
                                                  Posted by Ramon Wilson on 10/11/2020 18:58:29:
                                                  If so bolt the topslide to your mill table, lock the gib and using a small cutter say 6mm-1/4" touch on in the centre area around the bolt hole and take very fine skims off until the milled area is all over – personally I would not use a fly cutter – despite the appearance of overlapped machining marks the face will be much flatter than if the fly cutter isn't perfectly true.
                                                  Been there, said that Neil wink
                                                  Flycutting is an easy way out, does give you a nice finish if the tool is right but does not, as you say, give you a perfectly flat surface. Possibly good enough for this instance but if it's on the mill why not carry out the job in a manner to ensure it is.
                                                  Ramon
                                                  #507296
                                                    If you must use the flycutter then take multiple passes with a small 5-6mm stepover which will eliminate any dishing caused by being out of tram.
                                                    #507306
                                                    Rod Renshaw
                                                      @rodrenshaw28584
                                                      Dr DMJN
                                                      I don't think I would try the abrasive paper, except perhaps as a very temporary expedient on just the block to see if it improves the grip. It seems to be the topslide surface which really needs improving. It takes a lot of rubbing to remove even a very few thou and some of those marks look quite deep. There is every chance of rounding the surface as you rub back and forth, especially so with the toplide which is an ungainly, unbalanced lump. An old timer would file and then scrape the cast iron surface flat to the surface plate, but that takes practice and more skill than most of us amateurs will ever have.
                                                      As you have a mill, it would be safer to mill back to a good surface as discussed in the last few posts. Or take up Duncan's idea and locate someone with a surface grinder.
                                                      Rod
