Minnie seal problems
Home › Forums › Help and Assistance! (Offered or Wanted) › Minnie seal problems
  • #252604
    David Bothwell 1
      @davidbothwell1
      I am having quite a bit of trouble with getting a good seal of this (Minnie 1" te) cylinder to the boiler. I have used 1/64th sheet gasket and also a sealing fluid on both sides, but air is escaping around the sides of the cylinder. I made my own screws from bronze 6ba, but reverted to stainless steel bought ones. I have/am considering either using bigger (5ba) screws, or doubling up on the gasket, i.e using 2 sheets! It pains me to admit it but I have broken heads off 2 screws (arghh!) so it has to come off! ANY suggestion gratefully accepted.
      #32767
      David Bothwell 1
        @davidbothwell1
        Sealing cylinder to boiler
        #252617
        nigel jones 5
          @nigeljones5
          apply Loctite 660 – it wont leak again!
          #252619
            What sealant did you use
            Did you machine the underside of teh saddle to boiler dia plus twice gasket thickness of to just boiler dia?
            #252621
            David Bothwell 1
              @davidbothwell1
              Thanks Fizzy, Jason I bought the model as a part made project I realised the underside of the cylinder (gunmetal) was a very bad fit to the boiler, so I set about putting it right with a rotary tool and sandpaper wheel. Unfortunately I did not realise how soft and easy the gunmetal was.Cut a long story short I have had to solder a piece if brass to the base which I though was a much better fit! I hop you are not horrified by this!!?
              #252641
              nigel jones 5
                @nigeljones5
                nah…..the other less reversible easy fix is to put it in place on a bed of jb weld,either wat it wont leak ever again!
                #252648
                  So it sounds like you have made the saddle a good fit on the boiler dia, if you now add 0.016" of gasket then the saddle will make good contact at the sides but not in the middle.
                  Options are to not use a gasket and go with a modern sealer as Fizzy suggests, or increase the radius of the saddle to take into account the gasket thickness which is best done by finding some abrasive sheet that is as close as posible to 0.016" and wrap some round the boiler. Now just rub the saddle over this in teh vacinity of where it will eventually fit until you have sanded the whole underside.
                  Going upto 5BA won't be a problem but you may need to use 6BA heads as there is very little room particularly front and back. To save snapping weaker bronze or stainless screws use steel ones first of all to pull thing sdown and then test once sealant has set. If all is OK then replace steel screws one at a time ading a bit of sealant to each new screw.
                  #252655
                  David Bothwell 1
                    @davidbothwell1
                    Many thanks for those excellent replies, upon which I will shortly be acrting of course, bank holiday may slow any progress, shops closed and all that. Other thingsto attend to on the model
                    #252666
                    David Bothwell 1
                      @davidbothwell1
                      Just out of interest just checked and one of the main suppliers of bolts does 5ba stainless with 6ba head, just ordered some
                      #253117
                      nigel jones 5
                        @nigeljones5
                        looking good…that Locomotive of yours!
