minature hydraulics and pneumatics
Home › Forums › Hints And Tips for model engineers › minature hydraulics and pneumatics
  • #289128
    Brian Smith 1
      @briansmith1
      Would anyone have any reference material on miniature hydraulics and pneumatics?
      • construction of small pistons (1-2cm stroke)
      • tubing attachments
      • air and fluid compression
      • etc
      interest is in the field of Automata (ala Disney below)
      #30604
      Brian Smith 1
        @briansmith1
        #289154
        Nick Hulme
          @nickhulme30114
          Softer seals will work for lower pressures.
          Job's a good 'un!
          #289155
            Take a look at some of the sites that focus on model heavy plant like earth movers, cranes, dump trucks etc.
            #289159
            alan ord 2
              @alanord2
              Brian, try researching "Fuidics and Low Pressure" control systems. I recall many years ago, before the proliferation of programmable electronic logic controllers, using fluidics for operating machine control valves etc. Nand's, Nor's And's, Or's, Flip Flops, etc.
              "Fuidics"!!!!!! should have spelt Fluidics.
              Edited By alan ord 2 on 16/03/2017 20:53:55
              #289162
              David Taylor
                @davidtaylor63402
                Very interesting info on the fluidic logic, thanks!
                #289180
                V8Eng
                  @v8eng
                  I remember a former colleague using pneumatic components supplied by RS Components, they stock all sorts of pneumatic and hydraulic equipment supplies, including some pretty compact items.
                  I have put a link here to the relevant index page on their site, hope it helps:
                  vintagengineer
                    @vintagengineer
                    Having spent many years working on the big stuff, I suspect friction is going to be your biggest challenge.
                    #289207
                    MichaelR
                      @michaelr
                      A lot of info on YouTube for model systems https://youtu.be/WaeEBXaj-vA
                      Edited By MichaelR on 17/03/2017 09:38:16
                      #289211
                      Nick_G
                        @nick_g
                        Model R/C aircraft use small pneumatics for retractable under carriages. Maybe worth a nosey for some ideas.
                        Nick
                        #289215
                        Ian S C
                          @iansc
                          Lego has a pneumatic system for activating models, uses a syringe similar to a medical one as the pump.
                          Ian S C
                          #289257
                          Brian Smith 1
                            @briansmith1
                            Thanks for all the replies so far.
                            Interesting videos…going to spend some time looking there
                            Fluidics search was interesting as well
