Milling Machine
Milling Machine
Home › Forums › Beginners questions › Milling Machine
  • #76202
    Wolfie
      @wolfie
      OK can anyone recommend a milling machine less than £1000 (much less preferably) suitable for a relative novice.
      Doesn’t need to be all singing and dancing etc, just be reliable and accurate.
      #5700
      Wolfie
        @wolfie
        #76203
        John Hinkley
          @johnhinkley26699
          You could do a lot worse than what I did – that’s buy an XJ12-300 from Amadeal. They are still quoting £412 inc VAT, which is what I paid a long while ago. You very much get what you pay for, does exactly what it says on the pallet and, in my humble opinion is an excellent machine for the beginner at a reasonable price. Be prepared to pay pretty much the same again for tools, clamps, vice, etc,etc …………
          Usual disclaimer – just a satisfied customer.
          michael cole
            @michaelcole91146
            What are you planning to make with it. Remenber it is just not the size of the table but the area covered by the cutter. The cross travel on smaller mills is normally to small to be usefull. I started off with a X2 mill ( too small) and moved up to a Chester Lux.The bigger the better as with all machine tools.
            #76231
            Wolfie
              @wolfie
              OK good point, what do you call a smaller mill then?
              #76404
              michael cole
                @michaelcole91146
                Unless you are making really small things the X2 size mills i think too small. There was just 90 mm y travel on mine. I was building a 5 inch loco at the time. My current mill a Chester Lux has 190 mm cross travel and you still have to think about placement on the table for the larger parts to be covered.
                #76408
                Springbok
                  @springbok
                  Hi Wolfie.
                  Depending on space the biggest you can get and afford but keep in mind all the other bits you will want, collets, cutters,rotary table, I could go on. Depending on the flavour of what you eventualy select they may throw in a vice but be prepared to buy a decent one as the “extras” are usualy chinese.
                  Good luck
                  Bob
                  #76415
                  Ian S C
                    @iansc
                    My Rexon mill has 280mm under the chuck, and thats some times a biy of a squeeze, so head room is quite important. Ian S C
                    #76416
                    Niloch
                      @niloch
                      The Warco WM18 has had a good review and seems to be an excellent mid-size machine. Check out delivery times from whomsoever you order. The Warco people are fair and pleasant to deal with. Usual disclaimer.
