Posted by JasonB on 29/01/2012 08:02:33:
Even less high tec than Terry’s suggestion if you don’t have a wiggler or edge finder you can alway use the good old fag paper.
With the mill NOT running touch the shank of the tool above the cutting edges on one side of the work so it just traps a fag paper, make a note of the handwheel reading. Do the same on the other side and divide the readings by two making any allowance for backlash. When you get the hang of it you can use the cutting edge rather than the plain shank
J
Hi Jason,
I also use that method, but since I gave up smoking many years ago I have to buy fag papers specially, I have also seen it done using strips cut from phone directories allowing for the thickness of the paper (about 4 thou’).
In a variation of your method I was taught to, stick the paper to the side of the job with good old fashioned spit, then with the cutter running, just very carefully move the job to the cutter until the paper is torn off the job by the running cutter. Never had a problem with that. The ‘sticky pin’ wiggler (plasticine and needle – very cheap) is also good for centering centre punch marks or cross hairs for drilling etc without the possibility of error with simple calculation error creeping in.
By the way slot drills (2 flute) rarely wander unlike end mills. 4 flute cutters cause an inbalance of forces to one side which tend to pull the cutter out of line, this is not the case with 2 flute slot drills. That is why you should use slot drills for slots and not end mills.
Best regards
Terry
