I have just ordered a new workshop as mine is just too small for what I plan this one is going to be 20' X 10'. Anyway I am also going to buy my lathe and milling machine, so be prepared for a few questions and I didn't mean what lathe or mill should I buy. Hoping to order these once my workshop is up and wired in
The first is reference the lathe I have seen the Warco WM250v variable speed and the wm250 lathe with inverter drive variable speed, would I be correct in saying the second model is better as regards the drive system.
Also what would the advantage of the WM280 with the separate shaft for cross feed
I have picked these sizes as I wish to start making beam style engines and then later as I learn a little a loco of some sort.
Also with milling tables which drive system is better the belt drive or gear drive. And also would there really be any advantage of a longer table other than the odd job which would require it. I am looking at one of the WM18 range of mills.
Expect more questions as they come to mind
