ME Vertical Boiler – Cap Exhausat (BF12)
Home › Forums › General Questions › ME Vertical Boiler – Cap Exhausat (BF12)
  • #27106
    Malcolm Farrant
      @malcolmfarrant93389
      #448847
      Malcolm Farrant
        I have nearly complerted the ME Vertical Boiler, but am confused.
        BF12 – The Cap Exhaust fitting is fitted to the Smokebox cap with the small pipe bent up into the chimney. Done, and understood, BUT the other end – on the top of the Smokebox Cap seems to have just an open end. …My question is that all there is to it or does the top portion then connect elswhere. I can find no information other than the fitting and bending the tube into the Chimney. There is a hedding in issue 4608 "Installing the Cap Exhaust fitting."
        Any advice and information much aprecxiated
        Malcolm Farrant
        #448852
          You run the exhaust from the engine back to fitting on th etop of the boiler and then it will go up the chimney to help with the draft.
          #449007
          Malcolm Farrant
            Thanks, that now makes sense.
            Best wishes
            Malcolm
