manual for ajax shaper
Home › Forums › General Questions › manual for ajax shaper
  • #451159
    paul fox 2
      @paulfox2
      just bought an ajax shaper but there is no model number on it that i can see the guy I bought it from thought it was an 18 inch but i think it may be 15 or 16 inch cut has both cross feed and down feed very nice machine does anyone have any idea where I can get a manual for it ? cant find anything online for it
      paul
      #27130
      paul fox 2
        @paulfox2
        #451221
        David George 1
          @davidgeorge1
          Ajax          https://www.ajax-mach.co.uk/shaping_machines.htm    try here.
          David
          Edited By David George 1 on 08/02/2020 10:06:26
          #451282
            None listed at the site below, but lots of other Ajax machines. May be worth an email?
            /store.lathes.co.uk/ajax
            Shapers are pretty straight forward once you've worked out the feeds and lubrication you should be OK.
            Oldiron
              @oldiron
              Should be very easy to determine the stroke length. Move stroke adjuster to end of slot. Then measure stroke. No might be's about it.
              regards
              #451303
              paul fox 2
                @paulfox2
                I will measure the stoke properly ( only got it thursday ) I know there is not a lot to them but there is an issue with the downward travis ( not working) simple to repair but would be nice to see the parts breakdown before I start also a dial at the rear of the machine that has two settings cant see what it might do, may be to do with the hydraulics not sure
                it has four speeds but to me the slowest looks fast enough for me the fastest is so fast cannot imagine using it
                its a really nice machine and has been well cared for by the sad to say late owner
                there seems very little on the net on atlas shapers other than the very small model, I have an atlas horizontal bandsaw but see the same bandsaw on the net badged by many different names but the identical saw
                I have also read atlas did not make machines just rebadged them with their brand so I wonder what make my shaper really is ? might make finding a manual easier
                paul
                #451346
                John Olsen
                  @johnolsen79199
                  The fastest speed may only come into its own when you are using very short strokes.
