machine coolant pipe
Home › Forums › General Questions › machine coolant pipe
  • #428262
    Ian McVickers
      @ianmcvickers56553
      Hi all.
      Has anyone found a supplier of flexible coolant hose at reasonable costs? I'm not talking about the plastic loc line stuff but the metal coil one. The only UK supplier I've found wants £50 plus £17 postage for one but I've found a USA supplier and the same one costs around $20, not sure about postage costs though.
      #26823
      Ian McVickers
        @ianmcvickers56553
        #428300
        stevetee
          @stevetee
          Could you not get a flexible spout from one of those sealey type parts washers as a spare part and use that.
          For example part number SM40D.V2-18 from a SM 19 parts washer.
          #428304
          Ian McVickers
            @ianmcvickers56553
            Steve, that will do nicely I think. Thanks very much. I tried all sorts of google searches but didn't think to go for a spare from something else.
            #428320
            Paul Lousick
              @paullousick59116
              Lots available on ebay. Including some with a control valve and magnetic base
              not done it yet
                @notdoneityet
                I suppose, for a steady feed, an oil can pipe might fit the bill?
                #428326
                Mark Rand
                  @markrand96270
                  These chaps seem to do what's needed. Either galvanised flexible steel exhaust hose (like the flexible conduit, but less leaky), or possibly their stainless steel over-braided marine fuel hose would fit the bill.
                  No connection with them, but I do need to look into some more robust flexible coolant hose for the milling machine, lathe and surface grinder!
                  Edited By Mark Rand on 10/09/2019 00:27:56
