Just a quick update – the inserts arrived yesterday – purchased 2.0mm and 3.0mm mainly because I haven't decided if I want to stay original on the screw yet and will need to make a nut anyway to go with it
So mounted a 1" bar for practice and machining away from the chuck for just a short distance to see how things went I was pleasantly surprised at the first time results, it actually looked like a lead screw….
Then noticed that the pitch didn't quite look right – Note to self first check that the gearing is set to match the insert….DOH had it set for 2.0mm pitch and used the 3.0mm insert
But at least I know I can now cut a LH Trapazodial Thread – Take that Warco..
Now to practice some more before working on the actual replacement blank shaft I made earlier
Good call about the inserts
cheers
