LED Fairy Lights
LED Fairy Lights
Home › Forums › Electronics in the Workshop › LED Fairy Lights
  • #827671
    not done it yet
      @notdoneityet
      Read my edited response!
      #827676
      not done it yet
        @notdoneityet
        Have you tried a 1.5V non-rechargeable cell?  Your rechargeable cell may not provide sufficient voltage to properly operate the lights.
        I note your initial post indicated a cell voltage more akin to a lithium cell or 3 x 1.5V cells as a battery.  Which is it?
        Is there any provision for an alternative power supply?
        With the correct voltage, the momentary button likely changes the mode of operation (on continuously, short or long flashing plus possibly some others).
        #827679
        Andrew Tinsley
          @andrewtinsley63637
          Just to add to the information. My solar powered LED string is DEFINITELY switched on and off by the Solar panel. No ifs or buts, no LDRs or phototransistors etc.
          Andrew.
          #827703
          Robert Atkinson 2
            @robertatkinson2
            1.2 volts (rechargable cell) is not enough to light a LED. The drive circuit will have a capacitive voltage doubler or similar.
            Robert.
            #827720
            Speedy Builder5
              @speedybuilder5
              Thanks Robert, I am guessing that something on the circuit board has stopped working such that the on/off switch latching circuit is not working. Its a case of ditching that bit and just saving the string of lights in the come in handy/useless bits box.
              Bob
