Leadscrew drifting out
Home › Forums › Help and Assistance! (Offered or Wanted) › Leadscrew drifting out
  • #269399
    Daniel
      @daniel
      Hello Everyone,
      I had a rather disturbing issue manifest itself today.
      I had decided to cut a screw thread (M10x1.5). Taking cuts of 0.02mm each pass, the thread gave the appearence of forming well. Then, after maybe 4 or 5 passes, I noticed the thread was looking less well.
      Being me, I continued regardless, until it became abundantly clear that no thread was going to get formed. It started to look like some very bad turning.
      On inspection, I see that the leadscrew has worked itself outwards, towards the tailstock; enough to have popped off the plastic end cap.
      The lathe is a Warco GH1322 and was new 12 months ago.
      In fairness, I have not yet contacted Warco.
      Does anyone have any ideas ?
      Thanks in advance,
      Daniel
      #32846
      Daniel
        @daniel
        #269401
        Gray62
          @gray62
          Sounds like the drive pin at the headstock end has either sheared or fallen out. On my Warco GH1330 it is a brass taper pin and it has come adrift in the past.
          #269403
          Daniel
            @daniel
            Hi Graeme,
            That might explain the 2 brass pins that came in the toolbag ; their application hitherto unknown thinking
            What kind of job was it to access the pin ?
            #269482
            Daniel
              @daniel
              Posted by Graeme W on 01/12/2016 18:29:14:
              yes
              Graeme,
              Sincere and heartfelt thank's for the pointer.
              You were absolutely correct.
              All repaired and ready to move on to the next learning experience laugh
              Thank's again,
              Daniel
