Knurling Wheel ‘Pins’
Home › Forums › Workshop Tools and Tooling › Knurling Wheel ‘Pins’
  • #202522
    HasBean
      @hasbean
      Gents, after a bit of advice here.
      I started making a Hemmingway knurling tool shortly after my daughter was born and seeing she starts her A level courses next week I thought it was time to get on and finish it!
      I'm at the stage of making the pins that the knurls rotate on but can't decide on what to make them out of.
      The plans call for hardened silver steel but I have heard (can't remember where from) that this may not be a good idea? Also I've read of them being made from 'plain' silver steel, old threaded endmill shanks (already threaded the frames so don't really want to try that), ordinary mild steel or bronze (I presume phosphor bronze).
      It won't get a huge amount of use but I'd rather that I'd not have to make up new pins on a regular basis smiley
      Any suggestions would be much appreciated,
      Paul
      #17813
      HasBean
        @hasbean
        #202523
        pgk pgk
          @pgkpgk17461
          I made mine out f silver steel and never got around to hardening them..but then i've only used the knurling tool once in the 4 mths since i made it..so wear isn't likely to be an issue..
          #202526
          KWIL
            @kwil
            Have worn mine with 20% step nowsad a few years use thoughsmiley
            #202527
            Jeff Dayman
              @jeffdayman43397
              Maybe use commercial purchased dowel pins? They are available in many sizes inch and metric, are relatively inexpensive, accurately ground, hard on the outside and tough on the inside, and always available. I used them in my homebuilt knurling tool with no trouble. Good luck, JD
              Alternately, drill rod / O-1/ silver steel would work fine too.
              #202529
              john carruthers
                @johncarruthers46255
                I used the shanks of broken taps, no problems so far.
                #202545
                Grizzly bear
                  @grizzlybear
                  Hi HasBean,
                  How about a 'Roll pin'
                  Regards, Bear..
                  #202548
                  Tony Pratt 1
                    @tonypratt1
                    Commercial dowel pins are your best option.
                    Tony
                    #202559
                      The ones I made with bronze pins show little wear after some 15 years of very occasional use.
                      I have a single wheel straight-in knurl I made that has done just 2 or 3 heavy jobs (e.g. knurling 2 1/2" steel). the temporary half-hard HSS drill shank spindle wore quite badly and I have fitted a bronze spindle to it.
                      HasBean
                        @hasbean
                        Thanks for all the replies gents,
                        I like the idea of dowel pins but as I'd like to be able to swap the knurls for different types I wonder if they'd become loose over a period of time? (Also I haven't found anyone yet who sells imperial pins that will post to Jersey).
                        I do have both silver steel and phosphor bronze so if you think that either of those will do I'll probably go down that route, I wasn't sure if un-hardened silver steel would be up to it (my resident blowtorch has died and the household financial controller has deemed it to be low on the priority list)!
                        Once again thanks for the replies,
                        Paul
                        #202619
                        Mick Henshall
                          @mickhenshall99321
                          For what is worth I made my knurling tool some years ago and have used it on numerous occasions with no problems using m6 bolts, there could be a problem running up to a shoulder but so far so good
                          Mick
                          #202622
                          Mick Henshall
                            @mickhenshall99321
                            20150831_110348.jpgHopefully her is a photo of knurler plus a hand held my Gramps made many moons ago
                            #202632
                            steamdave
                              @steamdave
                              If using tough/hardened pins, you will not get wear between the pin and knurl. If the pin rotates in the arm, it will be the arm that wears.
                              So, if it is not specified on the drawing, ensure you secure the pins from rotating, e.g. by grub screws or threading and nutting the pins to the arm and then you are free to use whatever material you have to hand. Making up new pins, if required will only take minutes.
                              The Emerald Isle
                              #202649
                              Ian S C
                                @iansc
                                Rollers from needle roller bearings work well. Ideally, a bronze bush in the knurling wheels is a good idea (or cast iron).
                                Ian S C
