The first one being good and subsequent ones poor suggests that a bit of swarf has become embedded in one of the knurls, lashings of cutting fluid reduces the chances of this happening but its advisable to check and scrub between jobs.
Verify that both knurls are spinning freely. Lots of pressure on small bearings so older units will be worn and can drag badly. Especially after Lawyer Murphy has inserted a couple of small pieces of swarf in positions exquisitely chosen to maximise problems.
I have a two wheel push knurl tool made by Pratt & Whitney of slightly unconventional configuration which seems rather better behaved than the usual sort. As usual with this style of tool the knurl carrier is pivoted so as to equalise the pressures on each however the pivoting arrangements are offset vertically so that one knurl contacts the work pretty much on centre whilst the other is pulled upwards onto the work. In the conventional tool the knurl carrier pivots pretty much on centre height so one knurl is above centre and one below. If the forces don’t balance out pretty well right from the start you have problems with the conventional tool. In contrast the P&W version is clearly unbalanced when you start but rapidly pulls itself in to making equal depth knurls. Its also tolerant of a nervous approach, standard practice with the conventional system is to be very firm when engaging.
That said I find that a hand held, “nutcracker style” three wheel tool gives good results without arcane practices or extreme verbal encouragement despite a rather low rent appearance. The two wheel clamp down type are generally well spoken of too. Both of these have the advantage of removing the heavy forces from the lathe. Important as many of the lighter machines aren’t really strong enough to generate the heavy shove needed to hold a knurling tool up to the work.
