Just wanted to share my Myford ML2
Home Forums Workshop Tools and Tooling Just wanted to share my Myford ML2
  • #119972
    rebekah anderson
      @rebekahanderson95322
      Just wanted to show off my newest addition.
      Photobucket Pictures, Images and Photos
      It's soooooooo much better than my C3 so that will be going soon.
      Any tips or idea's for tools to add to it.
      Edited By rebekah anderson on 15/05/2013 22:19:07
      #17081
      rebekah anderson
        #119978
        Chris Heapy
          @chrisheapy71135
          What a lovely looking verteran machine. The pedigree is there for sure. A fine aquisition.
          #119979
            That looks very tidy !
            … is the Black Box [below the HeadStock] your Motor Control?
            … or do you have an Electronic Leadscrew fitted?
            Edited By Michael Gilligan on 15/05/2013 22:52:36
            #119981
            Robbo
              @robbo
              One smart machine. Click on the pic fellas to see another view. Like the control box – is it a home brew or ready-made?
              Phil
              #119983
              rebekah anderson
                Yep the black box has the on/off switch, speed control and forward/reverse switch.
                It has a single to three phase converter for the three phase motor. There is a gas strutt for the tension on the belts and by pulling it in you can change the belt position.
                lead screw is controlled by a lever, forward/neutral/reverse.
                There is also a steady with it.
                I am so in love with it. Got it today, used it today and the results are superior.
                #119984
                rebekah anderson
                  I bought it as is, but it was reconditioned and rebuilt by a guy in lincoln.
                  He used ML7 gears
                  #119993
                  Hopper
                    @hopper
                    Lovely looking little machine. Those old lathes can still do a sterling job if sorted right.Have fun!
                    #119994
                      Well-seasoned castings, and probably fettled to better-than-new
                      … It should last you a lifetime … Do good work together !
                      Brian Wood
                        @brianwood45127
                        Hello Becky,
                        Just harking back to our earlier exchange on these older Myford lathes, it looks as though yours comes with the non offsetting tailstock. I really would advise against setting it over for cutting tapers, the realignment hassle later on is a real pain.
                        If it is aligned correctly now then use a boring head with a dummy centre for any such work, it will of course need to be on a 1MT fitting.
                        Myford offered replacements with a built in cross bar for similarly built tailstocks on the ML4 models that followed but not until well after 1945 when my Dad acquired his; I remember well the frustrations involved.
                        I think you will have endless enjoyment in your new toy, far better than the C3. I built my DW vertical mill using Dad's
                        Regards Brian
                        #120274
                        TD4
                          @td4
                          Hi RA. What a butiful lathe, I am still waiting for mine. Thanks to a forum member I have been reading reading, but untill I have mine I feel envious. May I ask one question, I love the colour is it up to each person what colour they want or are there different colours for different models. Malcolm.
                          #120281
                          rebekah anderson
                            Hiya,
                            well i'm over the moon as you'll be. As to the colour? I don't know. I just feel i got a bargain. At £410,- i feel i got a bargain.
                            I now need to learn how to cut threads on it. But that is another thread lol
                            #120379
                            TD4
                              @td4
                              Yes RA. you got a bargin, and I still love the colour. Malcolm
                              #120385
                              MadMike
                                @madmike
                                Rebekah, is it an optical illusion, or is the lead from the big red nuclear weapon launch button really running behind the chuck and in the "swarf2 area???? If it is then you should re-route it ASAP. HTH.
                                Nearly forgot. Lovely looking lathe, congratulations and enjoy.
                                #120388
                                rebekah anderson
                                  Nah optical illusion lol. Does look dodgey smile d
                                  #120391
                                  NJH
                                    @njh
                                    Well the "Proper" colour is pretty much the same grey as your bench!  ( Known , I believe, as:-  "Paint Light Battleship Grey" -or it was by GPO telephones who used a similar colour on their apparatus racks) The blue looks much smarter though and it will not reduce the performance of the lathe at all! wink Big cuts are not on the agenda but just learn to listen to your lathe, take it easy, and the two of you will have hours of fun together. My first lathe was an ML4 – very similar to yours – and I sold this on to a mate when I bought an ML10. He still uses and enjoys the ML4 which was an old lady when I bought her.
                                    Cheers
                                    Norman
                                    Edited By NJH on 21/05/2013 18:11:14
